turboing a mini me
Old May 16, 2007 | 10:11 AM
sony224422's Avatar
Default turboing a mini me
As of right now, i have a stock d15b8. The 8 valve is a piece and shes slow. I was going to do a y8 mini me, but then I realized i'll have 12:1 for compression.. wouldn't that be too high for boost?
The turbo i have is a 15g, which will be running 7-9 psi.
Will it be less effective or will it be okay?
Old May 16, 2007 | 10:28 AM
stockb18c's Avatar
na you will have 10.65 compression and 7-9 psi wouldnt be to bad with a good tune..
Old May 16, 2007 | 10:43 AM
sony224422's Avatar
Default Re: (stockb18c)
well i was thinking of doing a phearables.net ecu, so hopefully it'll be a good tune.
Old May 16, 2007 | 01:46 PM
wakedoe's Avatar
Default Re: turboing a mini me (sony224422)
why risk it and break the ringlands off. get some 75mm vitaras for like 130 that'l put you at lower compression.
Old May 16, 2007 | 02:44 PM
Joseph Davis's Avatar
Default Re: (sony224422)
Don't boost on a basemap, especially not phearable's. It'll start your car and drive it down the road pretty well, but the boost tables have been a bit off on a couple that I touched. Not that it matters. They are basemaps and nothing more.
Old May 16, 2007 | 03:08 PM
sony224422's Avatar
Default Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Don't boost on a basemap, especially not phearable's. It'll start your car and drive it down the road pretty well, but the boost tables have been a bit off on a couple that I touched. Not that it matters. They are basemaps and nothing more.</TD></TR></TABLE>
what will happen after that? will i have alot of problems? What should i do to tune it.. i know taking it somewhere is the best thing, but what if i can't do that.. or i just need it to start it to drive it somewhere to get it tuned?
Old May 16, 2007 | 04:16 PM
Well, after that you should get it tuned. What will happen is your car runs well and doesn't **** the bed.
Old May 16, 2007 | 04:41 PM
sony224422's Avatar
haha. Okay, i'll probably get his and run basemaps until i can get it tuned.
FTNW
Sep 26, 2012 09:03 AM
rsx13k
May 25, 2007 12:38 PM
b18sihatch
Aug 16, 2006 10:01 AM
one slow coupe
Mar 19, 2006 05:52 PM
Coppertop
Aug 25, 2005 12:18 PM
