b16 struggling, feels sluggish
Old May 13, 2007 | 08:14 AM
EM1-23's Avatar
Default b16 struggling, feels sluggish
hey guys i had a jdm integra type r swapped into my em1 a couple of years a go. Now i swapped the stock b16 back due to smog reasons and trying to keep it legit. Ever since i swapped the b16 it really struggles to get up there. It feels real sluggish, the rpm seems to stay in one place. I took my type r cams that I had in the type r and swapped into the b16. Could this be the problem? By the way i changed the timing belt water pump, headgasket, plugs and plug wires on the b16. Thanks
Old May 13, 2007 | 08:15 AM
cambopheonix56's Avatar
Default Re: b16 struggling, feels sluggish (EM1-23)
Check oil? What ecu are you using? Is the vtec engaging?
Old May 13, 2007 | 08:17 AM
EM1-23's Avatar
Default Re: b16 struggling, feels sluggish (cambopheonix56)
im using stock ecu and vtec does engage. I did check the oil.
Old May 13, 2007 | 08:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1-23 &raquo;</TD></TR><TR><TD CLASS="quote">im using stock ecu and vtec does engage. I did check the oil.</TD></TR></TABLE>
Is the oil old? Could be as thin as water and loosing pressure when you get up in the rpms. My buddies b16 did this until we changed the oil.
Old May 13, 2007 | 08:35 AM
EM1-23's Avatar
do you mean old oil from the past? the motor was drained when it was stored. i put fresh oil when i swapped it back. do u think it's just the sluge since it has been sitting? should i change the oil again? thanks bro.
Old May 13, 2007 | 09:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1-23 &raquo;</TD></TR><TR><TD CLASS="quote">do you mean old oil from the past? the motor was drained when it was stored. i put fresh oil when i swapped it back. do u think it's just the sluge since it has been sitting? should i change the oil again? thanks bro.</TD></TR></TABLE>
I doubt that, since you just changed the oil.. I don't know what to tell you otherwise, bump for an answer
Old May 13, 2007 | 09:22 AM
MidwestCartel
Guest
Posts: n/a
well im betting its fuel
Old May 13, 2007 | 09:25 AM
Default Re: (MidwestCartel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestCartel &raquo;</TD></TR><TR><TD CLASS="quote">Banned 8/27/07 for being so kickass.l</TD></TR></TABLE>
How do you know you will be banned in the future?!
Old May 13, 2007 | 09:35 AM
MidwestCartel
Guest
Posts: n/a
I predicted the date of my previous ban, maybe 2x prediction makes me a prophet.
Old May 13, 2007 | 01:36 PM
EM1-23's Avatar
bump
From_love
Sep 15, 2006 12:18 AM
4dr*sleeper
Jul 26, 2005 08:24 PM
Suck my DX
Jun 12, 2005 02:09 PM
SpoolnG2
Nov 11, 2003 07:57 PM
