b16 struggling, feels sluggish
hey guys i had a jdm integra type r swapped into my em1 a couple of years a go. Now i swapped the stock b16 back due to smog reasons and trying to keep it legit. Ever since i swapped the b16 it really struggles to get up there. It feels real sluggish, the rpm seems to stay in one place. I took my type r cams that I had in the type r and swapped into the b16. Could this be the problem? By the way i changed the timing belt water pump, headgasket, plugs and plug wires on the b16. Thanks
Re: b16 struggling, feels sluggish (EM1-23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1-23 »</TD></TR><TR><TD CLASS="quote">im using stock ecu and vtec does engage. I did check the oil.</TD></TR></TABLE>
Is the oil old? Could be as thin as water and loosing pressure when you get up in the rpms. My buddies b16 did this until we changed the oil.
Re: b16 struggling, feels sluggish (cambopheonix56)
do you mean old oil from the past? the motor was drained when it was stored. i put fresh oil when i swapped it back. do u think it's just the sluge since it has been sitting? should i change the oil again? thanks bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1-23 »</TD></TR><TR><TD CLASS="quote">do you mean old oil from the past? the motor was drained when it was stored. i put fresh oil when i swapped it back. do u think it's just the sluge since it has been sitting? should i change the oil again? thanks bro.</TD></TR></TABLE>
I doubt that, since you just changed the oil.. I don't know what to tell you otherwise, bump for an answer
Re: (MidwestCartel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestCartel »</TD></TR><TR><TD CLASS="quote">Banned 8/27/07 for being so kickass.l</TD></TR></TABLE>
How do you know you will be banned in the future?!
