turbo fins
Old May 12, 2007 | 04:12 PM
integlude's Avatar
Default turbo fins
how percise are the exhaust fins
i mean when i bolted my turbo together it was on a bind and i didnt notice it
then i started it and it didnt spin for a couple of seconds and then it sraped for a minute
i took it a part and it looked like the fins where bent over ar curled over a little
anyway it is back together now it it just doesn't feel good it feels fine till like 5 grand and it it is like mute it is at like 12.7 afr throught out the rest of the rpm range but just doesn;t pull at all
is it possible for exhaust to fly by the fins if they where bent a little
Old May 12, 2007 | 04:22 PM
turbo_ls_69's Avatar
do you have any pictures of the exhaust fins?
Old May 12, 2007 | 04:27 PM
integlude's Avatar
maybe by tomarrow
Old May 12, 2007 | 07:39 PM
HiProfile's Avatar
Default Re: turbo fins (integlude)
I don't know about you, but whenever I put a turbo back to gether, i ALWAYS spend a few minutes spinning the blades with my fingers, making PHHH sounds and such.
If the fins are curled over, chances are your turbine wheel (and shaft, all 1 peice) is junk. There's a good chance its out of balance now, and more likely than not that it will not flow like before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlude &raquo;</TD></TR><TR><TD CLASS="quote">and it it is like mute </TD></TR></TABLE>
I can't recall seeing the word 'mute' used in that way. I've tried, but I'm still clueless.
Old May 13, 2007 | 05:11 AM
integlude's Avatar
not gaining power any more
Old May 13, 2007 | 07:09 AM
miro_gt's Avatar
Default Re: (integlude)
out of ballance =&gt; can't spin fast =&gt; can't pump much air =&gt; you don't have that much power
Old May 13, 2007 | 07:34 AM
a1320addict's Avatar
Default Re: (miro_gt)
[QUOTE=HiProfile]I don't know about you, but whenever I put a turbo back to gether, i ALWAYS spend a few minutes spinning the blades with my fingers, making PHHH sounds and such. QUOTE]
bahahahaha.
Old May 14, 2007 | 06:09 AM
integlude's Avatar
working on the pics
just so busy
Whig-it
May 30, 2007 08:27 PM
ppfalcon
May 1, 2006 09:26 PM
truesleeper
Apr 14, 2005 07:03 AM
jwork101
Jul 4, 2002 07:15 PM
BlwnBlue
Oct 9, 2001 10:09 AM
