Removing Drum Cover? And Ebrake line?
Old May 10, 2007 | 08:20 PM
Civicman86's Avatar
Default Removing Drum Cover? And Ebrake line?
Anyone know how to do this? I cant get the damn thing off for the live of me. (98 EX). Also whats the easiest way to disconnect the e brake cables?
Im doing a disk conversion on the car. (I know I dont need the covers off to do this but I want to know how to do it lol).
TIA
Old May 11, 2007 | 03:09 AM
Team RS2's Avatar
Default Re: Removing Drum Cover? And Ebrake line? (Civicman86)
dont need to remove the drum cover, just the cable get under the car and unbolt the 2 brackets from the chasis and fish it out
but easiest way to remove the drum cover is to remove the screws, then spin and hit the drum cover until most of the dust is out and the bead is broken looe and itll slide off, dont be afraid to really beat that thing
Old May 11, 2007 | 04:46 AM
Civicman86's Avatar
lol i have beat the sh*t out of it it because I dont need them and I still cant get it off. Do you have to take the center cap off to get it off?
Old May 11, 2007 | 04:56 AM
EE_Chris's Avatar
Default Re: (Civicman86)
I've read that over time the rear brake shoes cut into the drum enough and leave a ridge for the drum to catch the shoe when trying to pull it off. So you have to go through the rear and pull the shoes in the with the star adjuster. When that's done, thread two bolts into the face of the drum to push it off.
Again, haven't done it...this isn't experience talking.
Old May 11, 2007 | 06:36 AM
Maireeka's Avatar
Default Re: (EE_Chris)
My drums were also stuck when I installed new shoes, threading 2 12mm (I think) bolts in to push the drum off works. Just keep tightening them until the drum pushes off of the shoes. If they're REALLY stuck, then using the adjuster to pull the shoes in (like chris said) should work.
Old May 11, 2007 | 11:14 AM
Team RS2's Avatar
haha this happened to me at at the dealership once, either someone over adusted the brakes or it just got rusty, try some brake cleaner it still might be the seal also what helps from my experence is actually spinning it and hitting it in 4 diff spots and eventually it comes loose lol,
but if your jus doing the disc swap unbolt the entire rear trailing arm and just leave the parking brake cable attached to the drum brakes you cant use them anyways and it just makes it easier
Old May 11, 2007 | 12:02 PM
Civicman86's Avatar
yeah that what i will probally do, i just want to see how bad the pads were lol
Old May 11, 2007 | 01:33 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">I've read that over time the rear brake shoes cut into the drum enough and leave a ridge for the drum to catch the shoe when trying to pull it off. So you have to go through the rear and pull the shoes in the with the star adjuster. When that's done, thread two bolts into the face of the drum to push it off.
Again, haven't done it...this isn't experience talking.</TD></TR></TABLE>
For not having experience you have nailed it on the head. tis is exactly what needs to be done
Old May 11, 2007 | 01:40 PM
EE_Chris's Avatar
Default Re: (B16b-EJ8)
Well...in that same thread, the reason it was discussed was because the o.p. found out the hard way what happens when you don't pull the shoes back in. So I've got that mental image sort of burned in now.
Old May 11, 2007 | 07:55 PM
Civicman86's Avatar
How do you pull the shoes in? I never did get the damn things off.
Good news though, the rear disks are on and working
Old May 11, 2007 | 08:03 PM
Team RS2's Avatar
get the prop valve in? i stripped 2 fing fittings on my car just now trying to do it ( i had the rears in and just found a prop valve, anf i just painted the motor bay etc all this custom **** lol)
Old May 11, 2007 | 08:38 PM
Civicman86's Avatar
is there a differnce between the si and ex prop valve?
Old May 11, 2007 | 08:43 PM
project civic's Avatar
this is funny cause i couldnt get the drum cover off either and was pounding on it for the longest time but its rather simple. There are 2 threaded bolt holes that just seems to be there for no reason lol, but find a bolt that goes in well and bolt it in one at a time and it'll push the cover right off. waala that was easy!
Old May 11, 2007 | 09:41 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">is there a differnce between the si and ex prop valve?</TD></TR></TABLE>
a wrolds diffrence lol
si = a 40/40 for rear disc brakes and ex's idk what they are but they dont feel good when you use the brakes, wiered pedal feel, best thing is tho is that the 40/40 could be found on integras or si civics and bolt right in place i heard a 91 ex sedan master cylinder was also a bolt on upgrade havent done it yet but ima check it out
Old May 12, 2007 | 07:08 AM
Civicman86's Avatar
Do I need to swap the brake booster stuff and Master Cylinder as well?
Modified by Civicman86 at 2:26 PM 5/13/2007
Old May 12, 2007 | 12:48 PM
Team RS2's Avatar
no
Old May 12, 2007 | 01:07 PM
Civicman86's Avatar
ok cool, thanks!
jbell
Honda S2000
16
Sep 18, 2008 06:26 PM
Da D0n
Feb 6, 2008 09:08 PM
cslegacy
Sep 11, 2007 11:47 PM
turboD16
Aug 26, 2002 06:20 PM
citanest
Oct 27, 2001 04:51 AM
