which wire on dimmer switch to wire tach light to
theres a black ground wire then there are two red wires....one thats all red and a red w/ black stripe....
herp me prease
herp me prease
Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">red/black stripe is parking light wire. you can also find this in an outlet in the front of the fuse box.</TD></TR></TABLE>
SO IS THAT THE ONE TO SPLICE INTO?
DOES THE RED/BLK ONLY GET HOT WHEN THE PARKING LIGHTS ARE ON, OR THE REGULAR LIGHTS AS WELL?
Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Actually it's the other way around, red/black is the pos.(+), [illumination circuit] the red is the ground for all dash lights that dim, the dimmer, [Dash Brightness Controller] controls the ground to the lights not the pos.(+)
Your tachs illumination needs to be connected to a 12V+ dimmer control to dim properly, or do what I did, open tach up disconnect illumination bulb(s) ground connect a lead to the bulb, ground side and run it out of the tach, connect the tachs illumination lead to the red/black and the ground you added to the red lead, done deal, fused at cars illumination fuse and brightness controlled along with rest of dash lights. 94</TD></TR></TABLE> I always listen when FCM speaks
Re: (CarbonizedDX)
lol why the hell would you do all that when you can just conect the white wire on the tach to any 12v and get the same result ? i would not open a tach up and do all that shyt its not needed
integraboi1010
05-30-2004 07:34 AM
Unjockable
01-27-2004 07:25 PM
LuderX
01-13-2003 05:49 PM
