Oil pressure guage question
Old May 30, 2002 | 04:32 PM
JMinSi2000's Avatar
Default Oil pressure guage question
I installed my oil pressure guage in my car, and when I turn my car off and my turbo timer kicks in, everything stays running, but the oil pressure guage goes to 0. Am I really getting no oil pressure when the key has been turned off or is it just the guage being stupid?
Old May 30, 2002 | 04:56 PM
Honda Hick's Avatar
Default Re: Oil pressure guage question (JMinSi2000)
Is it a mechanical or electrical oil pressure gauge? If its mechanical, they don't lie. If its electrical you probably have the power going to it from a source that turns off with the ignition.
Old May 30, 2002 | 06:51 PM
JMinSi2000's Avatar
Default Re: Oil pressure guage question (Honda Hick)
Its electrical...I'm pretty sure its just turning off. It doesnt sit on the 0 like it does when I turn the key to Ign before I start it. It sits kinda below it so i'm sure its just the power going off on it.
Old May 30, 2002 | 07:58 PM
Replica_Racer's Avatar
My gauges (oil pres., air-fuel,water temp) all turn off when the turbo timer kicks in.
Old May 30, 2002 | 08:56 PM
Coldsi's Avatar
Default Re: Oil pressure guage question (turboorangecx)
You only get oil pressure when the engine is running.
Old May 30, 2002 | 09:13 PM
Wide Open Throttle's Avatar
Default Re: Oil pressure guage question (Coldsi)
if it's an electronic gauge it will turn off when the ignition is turned off. if it's mechanical it will cease to read pressure when the engine is turned off. very simple.
Old May 30, 2002 | 10:19 PM
inspyral's Avatar
is engine is running, via the turbo timer.
Old May 31, 2002 | 08:58 PM
Coldsi's Avatar
Default Re: Oil pressure guage question (inspyral)
is engine is running, via the turbo timer. [/QUOTE]
My bad, I didn't read it completely. Seems like the gauge should display oil pressure when the timer is on, unless your wire hook up is on the wrong wire.
Old Jan 20, 2003 | 11:12 AM
integra-modder's Avatar
When you intslled your guages, you wired them to an ignition + 12 wire which gives you power when the ignition is on. The turbo timer is a hack which keeps the car running even after your ignition is off. So when you pull the key out, you lose power from your electric guages, and thus they dont work.
(760)doogie
Apr 26, 2008 08:40 AM
AJxr
Jun 17, 2007 05:55 PM
shannon
Jan 17, 2004 10:27 PM
15psi of fun
Jul 23, 2003 08:16 AM
