Disck brake swap
Old May 1, 2007 | 12:19 PM
B bOy CrAyOn's Avatar
Default Disck brake swap
i was wondering if anyone has the link to a how to write up on how to swap front disk brake set ups.. my hatch has a rear disk brake swap already but i have a whole front end of a 00 SI and i wanted to upgrade the fronts to the larger SI brake system... just wanted to see if anyone had a write up with pics of how to or somthing along those lines
thank you
Old May 1, 2007 | 12:22 PM
bmoua's Avatar
Suspension/Brakes:
https://honda-tech.com/zerothread?id=152884- Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=514109- 96-97 JDM ITR 4 Lug Brake Information
https://honda-tech.com/zerothread?id=811892- ITR 4 Lug onto EK
https://honda-tech.com/zerothread?id=514109- ITR Brake Thread
https://honda-tech.com/zerothread?id=333061- Five Lug Conversion
https://honda-tech.com/zerothread?id=1036267- GSR Suspension into EG
https://honda-tech.com/zerothread?id=812062- Integra Rear Discs onto EG
https://honda-tech.com/zerothread?id=820484- Full Brake Swap for EG
https://honda-tech.com/zerothread?id=641639- EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=1513752- How to put X Brake Setup on an EK
https://honda-tech.com/zerothread?id=641639- Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365- Integra Brake Swap
http://home.socal.rr.com/civic...x.htm- Cutting Away Old Control Arm Bushings and Using New Ones
https://honda-tech.com/zerothread?id=490117- Tie Rod End Removal
https://honda-tech.com/zerothread?id=1031874- Changing Tie Rod Ends
http://home.earthlink.net/~civ....html- Bolt and Washer Camber Fix
https://honda-tech.com/zerothread?id=481704- Jim Fab Traction Bar Install
https://honda-tech.com/zerothread?id=555391- HX Wheels on GSR or Si
https://honda-tech.com/zerothread?id=861481- Rear Lower Tie Brace Install
https://honda-tech.com/zerothread?id=972851- Front Tower Bar Install
https://honda-tech.com/zerothread?id=1079213- Lower Tie Brace Install
https://honda-tech.com/zerothread?id=1078663- Coilover Sleeve Install
https://honda-tech.com/zerothread?id=1278794- Installing Lowering Springs
https://honda-tech.com/zerothread?id=600967- NSX Calipers
https://honda-tech.com/zerothread?id=864784- Brake Rotor Replacement
https://honda-tech.com/zerothread?id=1317231- Quaife Steering into EG
https://honda-tech.com/zerothread?id=1427142- Shock/Strut Removal of EG
https://honda-tech.com/zerothread?id=1484555- Integra GSR Sized Brakes While Keeping Stock DX Civic Knuckles
https://honda-tech.com/zerothread?id=1437513- Blank vs. Cross Drilled Rotors
check all of those out bro...what car is this going into?
Old May 1, 2007 | 12:24 PM
00 si front disk brakes on to a 93 hatchback dx
Old May 1, 2007 | 12:25 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (B bOy CrAyOn)
i dun think thats swapable man
Old May 1, 2007 | 12:28 PM
BlueIntegraBoy's Avatar
Default Re: Disck brake swap (B bOy CrAyOn)
This link has pics.
https://honda-tech.com/zerothread?id=820484 (You'll reuse your UCA, so unbolt from top balljoint)
Old May 1, 2007 | 12:29 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Disck brake swap (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">i dun think thats swapable man </TD></TR></TABLE>
Why not?
Old May 1, 2007 | 12:32 PM
bmoua's Avatar
its swappable bro...you will need the rotors,pads, calipers, and spindle. Basically what blueintegraboy said...i'll be helping my buddy do his front gsr disk brakes tomorrow...
* B A N N E D *
Default Re: Disck brake swap (ek forever guy)
he wants an ek front set up on an eg?
Old May 1, 2007 | 12:40 PM
well im not gonna be using the suspension off of an ek.. just the brake set up.... so is this wappable or not ?
Old May 1, 2007 | 12:44 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B bOy CrAyOn &raquo;</TD></TR><TR><TD CLASS="quote">well im not gonna be using the suspension off of an ek.. just the brake set up.... so is this wappable or not ?</TD></TR></TABLE>
If you are swapping complete front hub's, then yes, it will all bolt up.
Old May 1, 2007 | 12:48 PM
* B A N N E D *
Default Re: (97Ej6mike)
my bad never heard of the swap before
Old May 1, 2007 | 02:13 PM
alright... then so it should all work out then cuzz i have the front hubs and everything
Old May 4, 2007 | 03:37 PM
wont i need a gsr brake booster and brake cylinder and what not ?
Old May 14, 2007 | 12:45 AM
Old May 14, 2007 | 05:38 AM
Ek Forever y0!
If you're getting bigger brakes and stronger pistons you need more power to use them Thus needing a bigger MC.
spintboy
Jul 13, 2008 06:57 PM
kpop
Jan 31, 2007 04:44 PM
92'si
10
Apr 21, 2006 02:18 PM
Kidnkorner
Nov 12, 2003 09:27 AM
