transmission will not hold the cv axle ????
Old May 1, 2007 | 12:23 AM
jdm_vtec's Avatar
Default transmission will not hold the cv axle ????
yea, so i just picked up a clean EJ8 (96 coupe), and the seller claimed his mechanic didn't put the axle in properly so he was selling it cheap.. well i got it to my house and went to fix the axle, and noticed it wouldn't go in all the way, and the gear that turns the axle inside is loose..
i tried lining that gear up and pushed the axle in, put everything back together and the first turn i made the axle popped back out.. what the hell would cause this? I guess I need another tranny
Old May 1, 2007 | 05:17 AM
jdm_vtec's Avatar
Default Re: transmission will not hold the cv axle ???? (jdm_vtec)
Old May 1, 2007 | 05:23 AM
sicones's Avatar
theres a little cir-clip or "set ring" on the end of the axle, you need to see if you even have one, or replace it
part# 11
Old May 1, 2007 | 05:26 AM
jdm_vtec's Avatar
Default Re: transmission will not hold the cv axle ???? (sicones)
i have the clip ring and it clicked when i pushed the axle in
Old May 1, 2007 | 05:27 AM
jdm_vtec's Avatar
the piece that turns the axle inside the transmission is loose and will push the axle out when it turns
Old May 1, 2007 | 05:28 AM
del_slow420's Avatar
i had the problem once... does the axle just slide in or do u need to hit it a little bit? try bending the cir clip sout some so it has a little more to catch on.. thats what i did and it worked fine
Old May 1, 2007 | 05:29 AM
sicones's Avatar
you mean the differential is loose as in wiggles, or just spins back and forth??
Old May 1, 2007 | 05:36 AM
jdm_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">you mean the differential is loose as in wiggles, or just spins back and forth??</TD></TR></TABLE>
it wiggles
when i was trying to put the axle in at first i noticed there was a lip on the differential splines that kept the axle from seating past the clip, then i had a friend turn the driver side wheel and it lined up.. i could move it up and down with my finger
Old May 1, 2007 | 05:44 AM
sicones's Avatar
the differential bearings are fucked, which is weird because those things are huge, anyway you need a new tranny or a rebuild
Old May 1, 2007 | 06:20 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">the differential bearings are fucked, which is weird because those things are huge, anyway you need a new tranny or a rebuild</TD></TR></TABLE>
That's what happens when you run a trans low on oil. Well at least you got a good deal on the car now you just need to find a new trans or rebuild that one
Old May 1, 2007 | 06:58 AM
jdm_vtec's Avatar
Default Re: transmission will not hold the cv axle ???? (instructor74)
problem solved, i just bought a good tranny and new axles and labor for the install for 350 :D
jayman66 is the best! buy parts and/or labor from him!
weese841
Honda Civic (2001 - 2005)
Aug 18, 2021 12:45 PM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
killacam661
Jan 4, 2009 03:17 PM
GSpeedR
Aug 11, 2002 03:06 PM
