vtec
Old Apr 30, 2007 | 10:49 PM
drewb16a's Avatar
Default vtec
whats up ht..i have a problem with my vtec.i dont hear my vtec open up.can anyone give me some insite ofwhat can be the problem.
Old Apr 30, 2007 | 11:08 PM
smileycvc's Avatar
Default Re: vtec (drewb16a)
only a bunch of diffrent things. SEARCH and welcome to honda-tech.
Old May 1, 2007 | 12:01 AM
BlueIntegraBoy's Avatar
Any CEL (check engine light)?
Old May 1, 2007 | 05:53 PM
drewb16a's Avatar
Default Re: vtec (BlueIntegraBoy)
yea the cel is on but its been on since i did the swap on the car.i have a b16 motor and a gsr ecu.
Old May 1, 2007 | 06:00 PM
excivicboy96's Avatar
thanks for the vague responses. WE NEED MORE INFO! did you attempt to check the code?
Old May 1, 2007 | 06:24 PM
First off, that's the wrong ECU to run the B16. You are probably getting a CEL for the IAB. Second, the stock GSR VTEC crossover is very quiet and less of a pop than if you were to run a B16 ECU.
Old May 1, 2007 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">First off, that's the wrong ECU to run the B16. You are probably getting a CEL for the IAB. Second, the stock GSR VTEC crossover is very quiet and less of a pop than if you were to run a B16 ECU.</TD></TR></TABLE>
true, he could also have mutiple codes if his cel has been on forever.
Old May 1, 2007 | 06:51 PM
Lscivic1999's Avatar
get a Pr3 ECU, right now im running b16 on my 99 EX i feel my vtec kicks in hard...even with my ls tranny..lol...
Old May 1, 2007 | 07:29 PM
drewb16a's Avatar
Default Re: vtec (Lscivic1999)
thanks i'll change the ecu and see if it still gives me a problem.
Old May 1, 2007 | 07:35 PM
seadonkeyraypiss's Avatar
Check the codes that your ECU is throwing first before buying a new one.
Old May 1, 2007 | 08:17 PM
drewb16a's Avatar
Default Re: vtec (seadonkeyraypiss)
how could i do that....im new to the honda game
Old May 1, 2007 | 08:36 PM
Libertariat's Avatar
Ek Forever y0!
There's a stick at the top of the thread for checking ecu codes.
https://honda-tech.com/zerothread/1901557
Old May 1, 2007 | 08:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seadonkeyraypiss &raquo;</TD></TR><TR><TD CLASS="quote">Check the codes that your ECU is throwing first before buying a new one.</TD></TR></TABLE>
He'll need to buy a new ECU anyways, he's running the wrong one
Old May 1, 2007 | 08:51 PM
drewb16a's Avatar
my vtec solenoid is kind of rusted could that be the problem????
Old May 1, 2007 | 08:58 PM
Tatakai's Avatar
the fact that he's running a gsr ecu wouldn't prevent vtec from working, and gsr's don't have a quieter vtec than b16's &gt;_&gt;
check you're wiring. what car is this b16 in?
the codes from the gsr ecu should be just the IAB/evap, vtec should still work @ 4400.
Old May 2, 2007 | 06:28 AM
Ek Forever y0!
Default Re: vtec (Tatakai)
He'll need to buy a new ECU anyways, he's running the wrong one </TD></TR></TABLE>
Oh, well running the ecu is probably his problem Lol
Old May 2, 2007 | 08:39 AM
daddycivic's Avatar
check oil level. Low oil=no vtec
Old May 2, 2007 | 07:16 PM
drewb16a's Avatar
Default Re: vtec (jz98ctr)
im sorry.......let me correct myself....1992 honda civic 4 door wiht a b16a swap with an ls tranny.i have dc sport headers 4-2-1 i also have a jackson racing superchanger with 12psi everything is port and polished...do i need to and anything else..like i said i am new to this....
Old May 2, 2007 | 07:21 PM
northkai3's Avatar
get an intake dawg.
down with this thread
Old May 2, 2007 | 09:17 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewb16a &raquo;</TD></TR><TR><TD CLASS="quote">im sorry.......let me correct myself....1992 honda civic 4 door wiht a b16a swap with an ls tranny.i have dc sport headers 4-2-1 i also have a jackson racing superchanger with 12psi everything is port and polished...do i need to and anything else..like i said i am new to this....
there ya go
Old May 2, 2007 | 09:38 PM
92'si's Avatar
did you buy the car like it is now?
Old May 5, 2007 | 06:56 AM
jz98ctr's Avatar
a 94 4 door...what chassis package??? is it an lx, dx?
if you don't know then do you have power windows, and locks, etc. ???
usually if you have the DX chassis there will be no wiring in the engine harness for vtec...
lamafia781
Jan 20, 2011 12:15 PM
93jdmh22a
May 16, 2010 10:52 AM
SilentHeaven
Jan 14, 2009 07:17 PM
ser13
Sep 11, 2007 09:04 PM
fastcat1
Dec 30, 2002 05:26 PM
