help clutch got screwed
Old Apr 30, 2007 | 05:03 AM
djsire's Avatar
Default help clutch got screwed
Yesterday when i was driving my car started leaking from what i think is called
either the clutch lever or clutch actuator. It is the piston that is located in front of the
transmission that moves when you press the clutch.
Now i need to replace it.
do i use a civic one or a prelude one.
And what is the correct name for that piece.
h22 eg civic.
thanks alot.
Old Apr 30, 2007 | 05:06 AM
97Ej6mike's Avatar
Its called the Master and Slave cylindar's. No you dont need a prelude setup, you just need to get a factory EG replacement one at either your local auto parts store, the honda dealer, or at a junkyard. Shouldnt cost a whole lot.
Old Apr 30, 2007 | 05:10 AM
djsire's Avatar
Default Re: (97Ej6mike)
just found out its the slave thanks. Im gonna run down and get the replcament. and do it my self. Now when i bleed it i just need to loosend the nipple on the slave right.
Old Apr 30, 2007 | 11:16 AM
djsire's Avatar
Default Re: (djsire)
ok just got the civic one and only one screw bolts into the tranny!
Old Apr 30, 2007 | 11:19 AM
instructor74's Avatar
Well this is now a no brainer it looks like you have an H22 swap in there so you will need on for the car that your trans came out of
Old Apr 30, 2007 | 11:21 AM
djsire's Avatar
Default Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">Well this is now a no brainer it looks like you have an H22 swap in there so you will need on for the car that your trans came out of</TD></TR></TABLE>
yes but braniac above told me i could get away with the civic one. obviously having no idea what he was talking about.
do you think i could get away with using one bolt
Old Apr 30, 2007 | 11:50 AM
If it was me I would just get the right one.Your just asking for trouble bolting it in with only one bolt. Next time you can check the part numbers and see if they are the same any parts store should be able to tell you if they are
Old Apr 30, 2007 | 01:05 PM
CiViC_SOHC's Avatar
you have to remember the people that post on these forums...some are retarded and you shouldn't trust and some are knowledgable...if you only use one bolt you have a tendancy for the push rod inside the slave to not put enough pressure on the shift fork in order to shift. So I would recommend getting a prelude one.
Old May 1, 2007 | 07:13 AM
djsire's Avatar
Default Re: (CiViC_SOHC)
doing that right now. and yes i will take that point into account
Old May 1, 2007 | 07:19 AM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">doing that right now. and yes i will take that point into account</TD></TR></TABLE>
He knows his **** he just didn't notice the part about the h22 swap..
Just go get an h22 slave master cylinder. And make sure it's for the non ATTS transmission as I believe the master/slave cylinder are different.
Old May 1, 2007 | 11:05 AM
djsire's Avatar
Default Re: (ek forever guy)
alreay done.
Bleeding was a bitch by my self.
think i might have to bleed again later on in the week with a freind
Old May 1, 2007 | 11:07 AM
djsire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
reread his post.
he clearly stated that i dont need the prelude setup. which means he did notice the part about the h22 swap
thanks for the help everyone
Modified by djsire at 8:34 PM 5/1/2007
H22AMedina
Jan 22, 2014 05:21 PM
djsire
Apr 30, 2007 06:12 PM
SleeprCivic
Apr 26, 2004 02:40 PM
j tek bb6
Aug 24, 2003 03:29 PM
