vibration during acceleration...help...
what can be the problem when during accel the car vibrates and when u let the gas off its stop vib. its a 94 eg hatchie wit ls motor. onlee on during accel it vibrates.....
#1 Super Guy
Re: vibration during acceleration...help... (deadline)
That is typically caused by a bad inner CV joint...
Check to make sure the boots are not torn open. If they are, replace the axles with some lifetime warranty parts from Autozone.
If they are not torn, check for bad motor mounts or any play in the suspension. Though play in the front suspension usually results in vibration during braking and not so much during acceleration (because of weight transfer)...
Ek Forever y0!
Re: vibration during acceleration...help... (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">motor mounts are ur friend.... tighten them </TD></TR></TABLE>
If his mounts were friend it would vibrate harshly 24/7.
I'm voting for CV joint or possibly wheel bearing/axle related problems.
Re: vibration during acceleration...help... (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">That is typically caused by a bad inner CV joint...
If they are not torn, check for bad motor mounts or any play in the suspension. Though play in the front suspension usually results in vibration during braking and not so much during acceleration (because of weight transfer)...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
I'm voting for CV joint or possibly wheel bearing/axle related problems.</TD></TR></TABLE>
the cv joints are clicking... problem solve
1 Post
Re: vibration during acceleration...help... (ek forever guy)
not necessarily... my rear tranny mount "after spec torque" still comes loose every like month ill have to retighten it an i can tell its coming loose because when i accelerate my car does that vibrating thing.. c/v's are a bitch sometimes too though haha.. oh well just tryna help
actually, if the mounts were bad they wouldn't vibrate 24/7.
think about it, when you accelerate, the engine is moving, if mounts were broken or loose the motor would send vibrations through out the car.
when you decelerate, the engine is going back to or is near the idle speed. where less/no vibration is felt.
trust me, i have broken plenty of mounts during my time.
I'm with you on this one
Re: vibration during acceleration...help... (B16b-EJ8)
i'll replace the axle..then i'll see if its still vib...then i'll check the mounts thanks for the help..
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">i'll replace the axle..then i'll see if its still vib...then i'll check the mounts thanks for the help.. </TD></TR></TABLE>
yeah im still stuck on the mounts though, only cuz i just had that problem about 29 hours ago lol... but if its an easy c/v fix too than good stuff..
#1 Super Guy
At least "check" the mounts & suspension before you go through all the trouble of replacing an axle...
2005, accel, acceleration, accelleration, acceloration, acura, civic, front, honda, integra, odyssey, vibrates, vibrating, vibration, wheel
