iacv?
My idling is to low below 500. I adjust the screw, but wouldn't help. Can it be my iacv? Instead of buying another iacv can i just take the iacv out from my manifold
and clean it? It's a 97 civic ex.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corryboi »</TD></TR><TR><TD CLASS="quote">i dont know exactly were the iacv is on my 96 dx civic can someone help?</TD></TR></TABLE>
Its on the backside of the IM. I has 2 bolts holding it in place, along w/ one or two hoses i believe? Someone correct me if im wrong. Pull the screen out, and spray carb cleaner on it...make sure to not get any on your TPS or you're fucked.
on the dx model the iacv is on the throttle body not on the IM. The ex IM have the IACV on the back sometimes, depending on the transmission I believe. The dx IM only has runners and the TB points up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrider »</TD></TR><TR><TD CLASS="quote">on the dx model the iacv is on the throttle body not on the IM. The ex IM have the IACV on the back sometimes, depending on the transmission I believe. The dx IM only has runners and the TB points up. </TD></TR></TABLE>
Right...but the OP said he has an EX
hehe sorry about that thanks for not flaming.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic »</TD></TR><TR><TD CLASS="quote">
Its on the backside of the IM. I has 2 bolts holding it in place, along w/ one or two hoses i believe? Someone correct me if im wrong. Pull the screen out, and spray carb cleaner on it...make sure to not get any on your TPS or you're fucked. </TD></TR></TABLE>
if not there then some ex models have it on the TB.
dth0ng69
25
May 18, 2009 08:30 AM
