very poorly swapped b16a2 eg
Old Apr 24, 2007 | 08:57 PM
badb16rex's Avatar
Default very poorly swapped b16a2 eg
just bought a very poorly swapped 93 eg with a b16a2 out of a 00si....problem is they used the si ecu and there are cut wires everywhere....the harness is completely useless....read through all the FAQs i could find and i did find the answer, but i found conflicting answers so i want some more advice....i know im going to run a chipped p28 and tune with crome, but a 96-01 gsr harness will be pretty much plug and play right? with a few minor changes, but it should work right?
Old Apr 25, 2007 | 05:21 AM
LS-V Turbo's Avatar
Default Re: very poorly swapped b16a2 eg (badb16rex)
I could be completly wrong but why are you using a obd 2 harnes with a obd 1 ecu. Maybe that is the proper way to convert back to obd 1 i don't now. Just woundering if im wrong let me know.
Old Apr 25, 2007 | 06:05 AM
dso's Avatar
dso
yes it should be fine i have a b16a and i ran it with my cousins gsr ecu (just for fun) and there was no difference, except for that fact that vtec engaged later.
Old Apr 25, 2007 | 06:20 AM
92redhatch's Avatar
no buy a 1992-1995 civic ex/si wiring harness. The only thing you have to change are the injector clips ( from obd1 to obd2 Unless you have obd1 injectors) and the alternator plug( from obd1 to obd2 unless you have an obd1 Alternator ) And lastly extend the o2 sensor plug. Its really simple. Took me no more than 1 hour.
Old Apr 25, 2007 | 09:54 AM
badb16rex's Avatar
Default Re: (92redhatch)
the reason i ask is because on one of the FAQ it said using a 96-01 GSR harness with a chipped p28 ecu will be ALMOST a straight plug and play even though the gsr harness is obdII.....i have only found this info in one post, so i wasnt sure if the guy was confused or if its really possible
Old Apr 25, 2007 | 10:04 AM
92redhatch's Avatar
ok but if you want to keep life a little easier go with a 1992-1995 ex/si harness
Old Apr 25, 2007 | 10:27 AM
93egsir's Avatar
I agree if the car is obd1 run an obd1 harness and modify what only what you need to because of the motor. what is the chassis. (dx,cx,si, etc.)
Old Apr 25, 2007 | 08:42 PM
badb16rex's Avatar
Default Re: (93egsir)
it is a 93 ex coupe....but the harness is so mangled its not worth saving.....plus he was running the 00 si ecu so i'm gonna run a chipped p28....also cant find a mirror for crome thats not working....tried registering on pgmfi.org but i never got my confirmation email
Old Apr 26, 2007 | 09:47 AM
badb16rex's Avatar
Default Re: (badb16rex)
bump....
Old Apr 28, 2007 | 12:08 PM
badb16rex's Avatar
94 gsr harness would work too wont it?
killaberna
27
Aug 26, 2014 06:44 PM
JDM_CAM23
Nov 15, 2011 12:24 PM
jamelin
Oct 10, 2009 04:53 PM
zamboolicious
Feb 6, 2008 05:44 PM
VTECdohcter
21
Jul 20, 2007 10:10 AM
