No vtec motor swap, already searched "vtec" "no vtech"
Old Apr 24, 2007 | 08:11 PM
2slow4stock's Avatar
Default no vtec on motor swap, already searched "vtec" "no vtech"
Acouple days ago I swapped in a d15b into my 90 crx si. I bought the conversion harness, 4 wire o2 sensor, etc for the swap.
Everything is bolted up, runs fine but no vtec... No check engine light, oil is full. I used my trans by the way, and kept the cable speedo. It has low end power but no top end. I'm running the p28.
Just wondering why i'm not hitting vtec. Is it fine to run the cable speedo? Everything is hooked up right. If anyone can please help that would be good. Running out of idea's. Thanks. Also i searched... "d15b" "vtec" "no vtec" none of those helped me at all.
Old Apr 24, 2007 | 08:18 PM
dr_latino999's Avatar
Default Re: no vtec on motor swap, already searched "vtec" "no vtech" (2slow4stock)
Any codes in the ECU?
Old Apr 24, 2007 | 11:22 PM
No codes what so ever. I ungrounded the vtec solenoid, just to see if I could pop a code and it did. Regrounded it and no more codes. So I know wiring is fine. None from the ecu also.
Old Apr 25, 2007 | 12:37 AM
black88si's Avatar
Default Re: (2slow4stock)
Just out of curiosity, how do you know vtec isn't engaging?
Old Apr 25, 2007 | 12:42 AM
abnaasefmb's Avatar
you are letting it warm up, right?
Old Apr 25, 2007 | 01:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (abnaasefmb)
I would hook up a VTEC indicator light to check and make sure because SOHC VTEC isn't the loudest or most distinct thing to hear/see
Old Apr 25, 2007 | 09:45 AM
Default Re: (black88si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black88si &raquo;</TD></TR><TR><TD CLASS="quote">Just out of curiosity, how do you know vtec isn't engaging?</TD></TR></TABLE> No sound, No power, also had acouple other buddies look at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">you are letting it warm up, right?</TD></TR></TABLE> Yes I am.
Old Apr 25, 2007 | 10:03 AM
black88si's Avatar
If everything is hooked up, you are throwing no codes, and the car is warm.........
I would say that vtec is likely engaging. It is designed to be a smooth quiet transition. You aren't supposed to hear it. especially if you are all stock.
Old Apr 25, 2007 | 10:15 AM
Tippyman's Avatar
Sufficient oil pressure?
Old Apr 25, 2007 | 10:20 AM
abnaasefmb's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Sufficient oil pressure?</TD></TR></TABLE>
X2
Old Apr 25, 2007 | 10:49 AM
Bejita's Avatar
What ECU are you running?
Old Apr 25, 2007 | 05:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black88si &raquo;</TD></TR><TR><TD CLASS="quote">If everything is hooked up, you are throwing no codes, and the car is warm.........
I would say that vtec is likely engaging. It is designed to be a smooth quiet transition. You aren't supposed to hear it. especially if you are all stock.</TD></TR></TABLE>. I have a fuel rail, AEM intake, lighten flywheel, full exhaust. I think the d16a6 was louder in top end. But I don't know...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Sufficient oil pressure?</TD></TR></TABLE> Yes I do. But i'm going to put in a oil pressure gauge, just incase it deciceds to go out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">What ECU are you running?</TD></TR></TABLE> The p28, got the ecu from a running car that was recked.
Old Apr 25, 2007 | 05:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">I would hook up a VTEC indicator light to check and make sure because SOHC VTEC isn't the loudest or most distinct thing to hear/see</TD></TR></TABLE> It's just so crazy it might work.
Old Apr 25, 2007 | 05:52 PM
SIred91's Avatar
Rainman
I have never felt vtec "kick in" in a basicly stock D series Vtec motor.
It just isn't all that.
Its probably working fine.
Old Apr 25, 2007 | 05:56 PM
Probably... But theres no power really. The compression on the motor is 175 all around.
But i'll keep doing stupid little tests. Theres no way that my old a6 beats this on low and top end. But any other info would help.
Old Apr 25, 2007 | 07:25 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow4stock &raquo;</TD></TR><TR><TD CLASS="quote">Probably... But theres no power really. The compression on the motor is 175 all around.
But i'll keep doing stupid little tests. Theres no way that my old a6 beats this on low and top end. But any other info would help.</TD></TR></TABLE>
Um, yeah, it does...haha..thats whats funny.
Old Apr 26, 2007 | 11:51 AM
(-.-) makes me want to swap my old a6 back in...
Old Apr 26, 2007 | 04:45 PM
I guess I hooked a light to the solenoid, and it works. I guess the d15b is just that weak... Thanks all.
b18c4civic
Jan 12, 2014 06:21 AM
swizz977
10
May 25, 2011 08:15 PM
MugeNinja
Dec 29, 2005 09:50 AM
cesareDOHC
Mar 6, 2004 02:53 PM
Z24hedturnr
Dec 14, 2002 07:29 AM
