vtec engagement problem
Old Mar 6, 2004 | 02:43 PM
cesareDOHC's Avatar
Default vtec engagement problem
I did an ls-vtec swap, the engine runs great but the vtec is not engaging. I tested the pressure switch and the vtec solenoid that was ok. When i put 12v to solenoid it engaged and vtec work, I am running a pr3 ecu and i get a vss code could that be what's not engaging vtec. I'm running it in a 89 crx with a cable operated speedo. please respond thankyou. (what else can i do to get it working)
Old Mar 6, 2004 | 02:53 PM
JohnnyEF's Avatar
Default Re: vtec engagement problem (cesareDOHC)
If you are getting a VSS code your Vtec will not engage.
HondacivDX
Feb 19, 2012 06:52 PM
nkcalvert09
Jun 11, 2011 10:43 PM
TristanW10
Mar 15, 2010 03:33 PM
MugeNinja
Dec 29, 2005 09:50 AM
JunY
Honda S2000
18
May 17, 2005 09:37 AM
