How to replace alternator on 93 Civic?
Old Apr 24, 2007 | 06:16 AM
supraken's Avatar
Default How to replace alternator on 93 Civic?
I took a look the other day and it seems like the space is really tight. I was able to loosen the top adjusting bolt that holds the alternator to the bracket, but it seems like there's no way I can reach the bottom bolt.
How do I remove this thing??
Old Apr 24, 2007 | 07:42 AM
Mr.EM1_EK's Avatar
Default Re: How to replace alternator on 93 Civic? (supraken)
jack the car up and get it from the bottom. you can get a haynes manual if you need pics. good luck
Old Apr 24, 2007 | 07:57 AM
pdiggitydogg's Avatar
yeah, you have to go in from under....and its still a bit of a pain in the *** - have to wiggle it around and try different angles to get it out and back in
Old Apr 24, 2007 | 08:02 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: (pdiggitydogg)
there is a 14mm nut and a long bolt on the alternator mount, tilt the alternator back to remove the belt there is no tensiorner so make sure you have a pry bar or long screw driver to re tension the alternator when reinstalling, i always find it easier to remove the entire bracket with the altornator keep the mount there, but take the bolt out with the nut, and i belive it is a 14mm bolt on the block near the timing cover (on the backside) of the block
Old Apr 24, 2007 | 08:28 AM
Luserkid's Avatar
Default Re: (spork motorsports)
If you take off the top bracket and move the MC from the BB you could take it from the top.
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">yeah, you have to go in from under....and its still a bit of a pain in the *** - have to wiggle it around and try different angles to get it out and back in</TD></TR></TABLE>
x2
Old Apr 24, 2007 | 11:27 AM
dpkelly's Avatar
Default Re: (B16b-EJ8)
You have to move the left driveshaft out of the way. It's like this for all 88-95 civics.
Old Apr 24, 2007 | 11:32 AM
B16b-EJ8's Avatar
Default Re: (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly &raquo;</TD></TR><TR><TD CLASS="quote">You have to move the left driveshaft out of the way. It's like this for all 88-95 civics.</TD></TR></TABLE>
It says this in the book for 96-00 as well...but i was able to pull it out from the top after pulling my strut tower bar, and moving a few other things out of the way...a lot easier than pulling the axle IMO
Fix_it_Yo_Self
Aug 2, 2017 12:03 PM
c4muzik
Aug 11, 2014 08:23 PM
y2kferari
Jan 7, 2009 09:10 AM
2ndGenREX
Sep 16, 2007 08:11 PM
--eclipse--
Jun 18, 2007 08:55 PM
