z6 swap
Old Apr 23, 2007 | 04:54 PM
eg6civic1538's Avatar
Default z6 swap
Im doing a D16Z6 swap on my 92 DX, could i swap the engine harness from an EX to a DX to run VTEC, instead of running the VTEC wire straight to the ECU...? would someone tell me how i could get around manually running it.. could i just plug it in somewhere?
Old Apr 23, 2007 | 05:15 PM
92ehatch's Avatar
Default Re: z6 swap (eg6civic1538)
you dont have to wire anything.
1992 civics were wired for vtec. all of them
you are plug and play man.
just get a p28 ecu
Old Apr 23, 2007 | 05:17 PM
iceman7329's Avatar
Default Re: z6 swap (92ehatch)
How about a 94 LX? Im might need a new engine to hold me over till my swap.
Old Apr 23, 2007 | 05:39 PM
1995Civic's Avatar
Default Re: z6 swap (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 &raquo;</TD></TR><TR><TD CLASS="quote">How about a 94 LX? Im might need a new engine to hold me over till my swap.</TD></TR></TABLE>
What about the 94 LX?
Old Apr 23, 2007 | 05:42 PM
i was just wondering because when people do mini me swaps they have to wire in the VTEC... why???
Old Apr 23, 2007 | 05:45 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to wire anything.
just get a p28 ecu</TD></TR></TABLE>
The Dash harness was prewired, not the engine harness.
What you could do is run the z6 harness or just use your harness and wire what you need into the shock tower instead of the ecu.
94 LX needs to be rewired.
Old Apr 23, 2007 | 05:52 PM
iceman7329's Avatar
Default Re: z6 swap (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
94 LX needs to be rewired. </TD></TR></TABLE>
Guess Ill stick with a 1.5 non vtec for now then. Thanks
Old Apr 23, 2007 | 06:00 PM
Ritchie's Avatar
so if you were to use a p28 ecu and SI wiring harness in a 92 civic, that's all you need to do?
Old Apr 23, 2007 | 06:08 PM
92ehatch's Avatar
Default Re: z6 swap (HondaEGG)
use the d16z6 motor (or head depending on the swap)
use the d16z6 engine harness
use p28 ecu
plug everything up
be done with it
Old Apr 23, 2007 | 06:17 PM
Ritchie's Avatar
i plugged everything up, but i am throwing a CEL 21, vtec solenoid. i tap the vtec solenoid to the positive terminal and it clicks. any reasons why this cel show up?
Old Apr 23, 2007 | 06:28 PM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEGG &raquo;</TD></TR><TR><TD CLASS="quote">i plugged everything up, but i am throwing a CEL 21, vtec solenoid. i tap the vtec solenoid to the positive terminal and it clicks. any reasons why this cel show up?</TD></TR></TABLE>
what year is your car, and did you use the d16z6 harness?
is everything plugged up?
Old Apr 23, 2007 | 07:00 PM
Ritchie's Avatar
1992 honda civic vx and yes i did use the d16z6 harness.
z71ondabottle
Aug 25, 2008 12:00 PM
jpizzi
11
Aug 29, 2006 12:56 PM
jjyynnxx
Aug 10, 2006 09:06 AM
Rocco.
10
Mar 13, 2005 01:52 PM
tolowhb
10
Aug 5, 2003 07:21 PM
