ROB BERING HELP
Old Apr 23, 2007 | 07:36 AM
eg8tuner's Avatar
Default ROB BERING HELP
OK SO I THINK I HAVE SPUN A ROD BEARING IN MY Y8 MY QUESTION IS CAN YOU CHANGE THEN WITH OUT PULLING THE ENGINE. I HAVE A LIFT SO GETTING IT OFF THE GROUND ISN'T AN ISSUE IM JSUT WOUNDERING IF IT IS FEASABLE.
oops srry for caps im in CAD class.
Old Apr 23, 2007 | 07:46 AM
Jay_Sensing's Avatar
Yes they can be changed with the motor in the car. If the crank or rod has sustained any damage at all though, it will desperately shorten the life of the new bearing since you didn't send it to the machine shop to be retrued.
Old Apr 23, 2007 | 08:01 AM
eg8tuner's Avatar
thx
im trying to get by for a couple months because i want to put a turbo on the engine so i will have it freshend up then but i just need it to run for now.
Old Apr 23, 2007 | 09:31 AM
Well, it's a quick job and it could last a year and could last 100 miles. All depends. I have seen both. Depends on if it's knocked long enough to hurt something.
Old Apr 23, 2007 | 07:17 PM
eg8tuner's Avatar
http://picasaweb.google.com/abenson100/BearingPrj
ok so i go tit apart and this is what greated me
Old Apr 23, 2007 | 07:22 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (eg8tuner)
nothing looks damaged, which one did you spin? it might be easier to remove the motor man, so you can do a full rebuild with vitara's and all that etc
Old Apr 23, 2007 | 07:30 PM
eg8tuner's Avatar
i got no cash or i would pluss i need the car back together by this weekend.
(auto-x)
the engine is going to be completely ripped apart later this summer for prep for the turbo but i need to save some money first.
Old Apr 24, 2007 | 07:45 PM
eg8tuner's Avatar
back to gether but taking it easy for a couple days
the #4 cylinder bearing was split in two on both the upper and lower and the #2 bearing was sun about 45 degrees.
all other bearings were suffering from severe wear.
did all bearing with the engine and crank in the car just have to take the time to make sure you don't screw anything up putting it back together cause its kinda hard to see some times (my drop light died)
luis253
Feb 13, 2015 06:05 PM
singlecamsaint
11
Jan 22, 2012 10:53 AM
Euro2JDM
Jan 10, 2007 01:23 AM
cor4ey
17
Sep 20, 2006 07:17 PM
pinecone
15
Jun 30, 2006 11:50 AM
