hitting red line
Old Apr 20, 2007 | 10:59 AM
redtegsr's Avatar
Default hitting red line
I have a 94 civic coupe ex with a gsr swap in it and when i try to take it to redline it hits rev limiter at around 7500, im throwing a code for knock sensor and also my oil sensor was unplugged so i plugged that back up and it was a little better but still sounded like it was straining to get to red line the motor it is a usdm bottom end with a jdm head
Old Apr 20, 2007 | 11:01 AM
SkertySkerty's Avatar
Default Re: hitting red line (redtegsr)
well first off do you have the correct ECU??? second off did you wire in the knock sensor??? let me know
Old Apr 20, 2007 | 11:59 AM
redtegsr's Avatar
Default Re: hitting red line (SkertySkerty)
yeah its a p72 and the knock sensor is wired in to the ecu
Old Apr 20, 2007 | 12:54 PM
stock99si's Avatar
reflash
Old Apr 20, 2007 | 03:12 PM
Default Re: hitting red line (stock99si)
Old Apr 20, 2007 | 03:15 PM
and yeah if your throwing a code for a knock sensor your **** shouldnt run... so blah i dont ****** know i'm having a brain fart today i cant effen think
Old Apr 20, 2007 | 05:50 PM
redtegsr's Avatar
Default Re: (SkertySkerty)
reflash? yeah it will run i dont think the knock sensor being bad will make the motor not run i need help
Old Apr 20, 2007 | 07:15 PM
jdmjeff's Avatar
Default Re: (redtegsr)
are you hitting vtec. im thinking that if vtecs not working then the car will not go to the redline which is like 8100... not sure though. make sure vtecs working.
take your ecu fuse out for 60 to reset your CEL codes then check the codes again. if its still throwin the knock sensor code try and fix it.
im throwin a knock sensor code and mine goes to redline just fine im thinkin that knock has nothin to do w/ it
Old Apr 21, 2007 | 12:02 AM
redtegsr's Avatar
Default Re: (jdmjeff)
yeah im hitting vtec or either im hearing the butterflies open up but i reset it like you said and still vtec but i picked up cel 10 which is iat intake air temperature, i tired my friend ecu which is one of those megan knock off ones and it disables the knock sensor and it was still straining to hit redline
Old Apr 21, 2007 | 11:12 AM
redtegsr's Avatar
bump
Old Apr 27, 2007 | 12:07 PM
redtegsr's Avatar
bump reallly need help with this
Old May 2, 2007 | 06:37 PM
redtegsr's Avatar
come on i tried my friends ecu and its sounds like it is straining to get to 8,000
Old May 2, 2007 | 06:47 PM
Techy's Avatar
Bump for this fella cause I'd like to know.
I have a similar issue with my B16A2. Throwing a CEL for code 91 FTP Sensor (hatchback ain't got one). Mine starts to limit at about 7600. Could it be my tach is inaccurate. It is after market (and I hate it but I can't afford a new cluster right now).
Old May 2, 2007 | 07:59 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (Techy)
Im not sure, but i don't think the knock sensor being unplugged will affect anything, same for the oil pressure switch... a friend of mine had a similar problem to this with his d16z6, but he wasnt the type to find out what was wrong so he loaded the "parts cannon" (wires, cap, rotor, plugs, fuel filter) and went to town. the last thing he replaced, cap and rotor watched him as he came across his loose distributor and the fact that it was laying all the way retarded as far as it would go. with all of these new parts on the car and finding that, re-timed and she ran perfect, but who knows what it actually was. Cover your bases and poke around, but remember if it were a sensor prob, most likely it would not go into VTEC. Oh and try to rev it past 7500 in neutral.
Old May 2, 2007 | 09:29 PM
redtegsr's Avatar
Default Re: (oneludesol)
ive tried the neutral thing and it still does it
Old May 3, 2007 | 05:22 AM
killaj12's Avatar
oil levels/pressure?
change ur oil, see if it helps?
Old May 3, 2007 | 05:42 AM
UNKNOWN_MEMBER's Avatar
probably your vtec isn't working and it's losing power up there? vtec hits 4500 butterflys 5000 something im not sure. but if you run open header you can for sure hear vtec at 4500 if it is working.
Old May 3, 2007 | 06:10 AM
Techy's Avatar
for me VTEC has always worked fine (and boy don't I know it). I've always kinda assumed the problem was wither the CEL or an inaccurate tach.
04silvep3
Feb 3, 2009 11:27 AM
adam081904
Mar 28, 2008 07:30 AM
luv2boost
Jul 5, 2007 09:43 PM
Phaze2 Mike
Dec 30, 2002 04:10 PM
clean99teg
Sep 21, 2002 05:43 PM
