knock sensor
knock sensor
ok so iv posted on here alot before i put a d15b jdm single cam vtec swap in my car an i new i didt have a knock sensor and my harness has the plug for it its a 1999 civic ex coupe so i finally got a knock sensor i pluged it in but i just let it hang there now i still get the same code for the knock sensor so but the sensor need to be grounded or what?
Re: knock sensor
I think your gona have to either run it with the CEL on if thecar runs fine without the knock sensor plugged in or chip the ecu. cuz im assuming that the ecu your running is not jdm so its gona read for the knock sensor. Correct me if im wrong
Re: knock sensor
yea its a p2p odb2b vtec single cam it wont pop vtec without the sensor i plug the sensor in the check engine compes back and vtec dosnt engauge
Re: knock sensor
haha no inspections down here my ecu has the wiring for a knock sensor the motor just dosnt have a place to put it the on the block its plugged in i still get the code tho
1SickHb
11-19-2004 04:39 PM
