e-brake stuck!
Old Apr 19, 2007 | 10:34 AM
Mikes2000civicsi's Avatar
Default e-brake stuck!
so guys...found out...e brake was stuck..didnt know for a while...pads are eaten down...how do i release the e-brake cable so its functional again
Old Apr 19, 2007 | 10:41 AM
92_civic's Avatar
Default Re: e-brake stuck! (Mikes2000civicsi)
you can use a pry bar or screwdriver to pry the arm that the cable attaches to back, this will release the e-brake
you need to determine what caused it to stick though
check your calipers, if the calipers check out it could be rusted cables not returning or as simple as the cables being out of adjustment
pry the arm back and have a friend pull the e-brake back up and release, see if it sticks again, if it does you will have to fix/replace whatever is making it hang up, or go without a e-brake
B_Swapped93
Jan 15, 2014 07:46 PM
ONEhaque
Nov 10, 2008 06:23 PM
Al-sonic
Jul 3, 2008 09:01 AM
coupe_hybrid
May 20, 2006 09:31 AM
Ricey McRicerton
Mar 27, 2004 07:16 AM
