ebrake does not work need help
the driver side works but the passenger doesnt work when i pull on the ebrake the rotors still turn if anyone know how to fix get back to me thanks
Re: ebrake does not work need help (Al-sonic)
could be one of 2 things you have a bad brake caliper or the ebrake cable is frozen. To check the ebrake cable remove the wheel. remove any shields that cover the ebrake mech on the caliper. remove the safety clip and pin that hold the cable to the caliper lever. Now you can have a friend work the ebrake handle up and down the cable should move freelly if it dosent replace it if it does then the problem is with the caliper and the caliper needs replaced
David12
07-30-2010 01:50 PM
