hmmmm
Old Apr 18, 2007 | 07:26 PM
egmatt93's Avatar
Default hmmmm
checked my CEL tonight and i have code 10 it says on here its for the iat sensor
but mine is fine... anyone know if the how to is wrong? i could of swore on the diy
before the current one codes 8 and 10 were different. also my speedomoter has been acting up. this started while it was raining so i figured the plug was wet, and
it was so i dried it out and it worked fine... today i drive to my grandparents
andeverything is fine, i go to leave and now my spedo isnt working. i checked the
plug again, it is dry but im not sure, i think the middle prong is broke... anyone happen to know how much a vss is for a b series or if i even need to buy a new one ( i really need help on this one fellas, hittin 2 step in ALL gears now ) any help greatly appreciated
Old Apr 19, 2007 | 10:14 AM
egmatt93's Avatar
Default Re: hmmmm (egmatt93)
bump
Old Apr 19, 2007 | 10:44 AM
92_civic's Avatar
vss for a b can be bought at a honda dealer, they have two versions, I think one lists for around 80-100$(us) and the other was around 150$(us) either will work
also check the wiring harness(engine harness) plug for corrosion, if it is corroded clean it out with some contact cleaner and grease it with some dielectric grease
OgulcanTR
Sep 13, 2018 10:09 PM
Steviebix33
Jul 23, 2011 09:02 PM
JaysonDC2
Mar 23, 2010 02:02 AM
90matthf
Jan 26, 2009 07:04 PM
misfit1
Feb 15, 2007 02:52 PM
