Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Will This Work?
Old Apr 18, 2007 | 05:44 AM
Killtodie's Avatar
* B A N N E D *
Default Will This Work?
http://cgi.ebay.com/ebaymotors...QrdZ1
is this gonna work for a 2001?
millage is stored in the ECU right? so it wont matter correct?
Old Apr 18, 2007 | 05:56 AM
Harlowe's Avatar
Function>Fashion
If you could get it wired and all, I don't think it would be a direct fit. The cluster would still read 23k if you got it installed though.
Old Apr 18, 2007 | 06:30 AM
fventura03's Avatar
mileage is stored on cluster. any cluster you get, that's not a 01-02 you will need to rewire to get it to work on your car.
Old Apr 18, 2007 | 06:35 AM
Killtodie's Avatar
* B A N N E D *
millage in cluster? that makes no sense.
when people swap ECUs it comes with special cables to transfere millage from the old to the new
Old Apr 18, 2007 | 06:58 AM
fventura03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killtodie &raquo;</TD></TR><TR><TD CLASS="quote">millage in cluster? that makes no sense.
when people swap ECUs it comes with special cables to transfere millage from the old to the new</TD></TR></TABLE>
you'd have to take it to honda to get them to reprogram the mileage for you. the mileage is stored on the cluster itself.
Old Apr 18, 2007 | 07:08 AM
Killtodie's Avatar
* B A N N E D *
ive had 4 other people tell me that its stored in the ecu just now
fventura03's Avatar
cool. well i'm telling you it's also in the cluster.
Old Apr 18, 2007 | 07:39 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (fventura03)
hahaha....
Old Apr 18, 2007 | 07:57 AM
InanimateCarbonRod's Avatar
Default Re: (ONLYuk7thGen)
Mileage is stored in the cluster. I believe this is the same throughout the industry. My coworker with a Chevy truck had to have a new cluster installed by the dealer and the dealer had to send the new cluster out to be reprogrammed with the real mileage.
Old Apr 18, 2007 | 08:10 AM
Killtodie's Avatar
* B A N N E D *
maybe its in both?
Old Apr 18, 2007 | 08:11 AM
fventura03's Avatar
maybe...
Old Apr 18, 2007 | 10:40 AM
Killtodie's Avatar
* B A N N E D *
so if i get a new cluster it will read the other cars millage and not my own?
Old Apr 18, 2007 | 10:45 AM
fventura03's Avatar
that's right. unless you pay honda to change the mileage for you, not sure how much that costs.
also, you're on your own about rewiring, to my knowledge, no one has done an ep3 cluster in an em2.
and i'm sure the spacing around the cluster won't sit flush without some modifying.
why do you want to make your car "look" like a civic si? didn't you say you were against that a couple of days ago?
Old Apr 18, 2007 | 10:57 AM
mrtrinh's Avatar
its stored in the cluster, ive swapped mine
Old Apr 18, 2007 | 01:25 PM
Killtodie's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">why do you want to make your car "look" like a civic si? didn't you say you were against that a couple of days ago?</TD></TR></TABLE>
I just want a better looking cluster. Hell, I just realized that it has SI written on it.
I like the 04 cluster, but hate it cause it has only 3 fields but like its trim.
Old Apr 18, 2007 | 01:29 PM
fventura03's Avatar
get it
civictyper96
14
Apr 14, 2010 02:56 PM
viskii420
Apr 16, 2006 10:23 PM
trick_db
May 14, 2005 02:56 AM
trooper0641
25
Apr 25, 2004 05:44 PM
