cluster
Re: cluster (trickek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickek9 »</TD></TR><TR><TD CLASS="quote">my cluster only work when i turn on my rpm how can i fix these?</TD></TR></TABLE>
wt do you mean??
wt do you mean??
Re: cluster (longbeachpurplecivic)
So you have aftermarket gauges? If so check your wiring. Also unless your rpm goes over 9000rpm, why even bother with an aftermarket guage?
no my cluster is not after market is stock si cluster on 98 hatchback...what it is, the cluster only work when i turn on my headlight, and my gas dont work even when i turn on my headlight, i ask 1 of my friend he say something wrong with the cluster or sensor i was just wondering if you guys have the same problem so i dont have to waste money on getting a new 1 if is cheap to fix thnx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickek9 »</TD></TR><TR><TD CLASS="quote">no my cluster is not after market is stock si cluster on 98 hatchback...what it is, the cluster only work when i turn on my headlight, and my gas dont work even when i turn on my headlight, i ask 1 of my friend he say something wrong with the cluster or sensor i was just wondering if you guys have the same problem so i dont have to waste money on getting a new 1 if is cheap to fix thnx</TD></TR></TABLE>
GRAMMER OWNS YOU BIG TIME yo.. the second description you made was still hard to follow by but i tried and this is what i came up with...
from what you are telling us, i am assuming that your bulb doesnt work. because you said when you turn on your headlights, that means your interior climate control and cluster should all light up.. but then you are telling us the gas doesn't work so go replace the bulb or check if its in securely. other than that a good, descriptive, and clear statement would be great to further assist you my fellow h-t member.
