fed up
Old Apr 17, 2007 | 07:29 PM
ALL5tar's Avatar
Default fed up
I cant get my effin car started. it will start a few times periodicly. ive replaced, fuses, relay, ignition mod. coil..starter seems to work"it makes noises" lol. im totly fed up. can anyone help ? any other ideas?
pce.
Old Apr 17, 2007 | 07:53 PM
Jokerluv's Avatar
bang on starter noid see if it works
Old Apr 17, 2007 | 07:56 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: fed up (ALL5tar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL5tar &raquo;</TD></TR><TR><TD CLASS="quote">I cant get my effin car started. it will start a few times periodicly. ive replaced, fuses, relay, ignition mod. coil..starter seems to work"it makes noises" lol. im totly fed up. can anyone help ? any other ideas?
pce.</TD></TR></TABLE>
since your starter is "making noises", i doubt banging on the solenoid will work. The car needs 3 things to run: AIR, FUEL, SPARK. You've checked for spark...but what about the other two?
Old Apr 17, 2007 | 08:04 PM
ALL5tar's Avatar
ya, i was wondering if you can check the fuel pump without droping the tank..?
Old Apr 17, 2007 | 08:23 PM
maynards_ek's Avatar
Default Re: (ALL5tar)
Have a friend turn the key to the "on" position, while you lie on the ground with your ear as close to the fuel tank as possible. If you hear the hum of the pump, then you know that is not your problem.
Old Apr 17, 2007 | 08:28 PM
fmrprojects's Avatar
Default Re: (maynards_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maynards_ek &raquo;</TD></TR><TR><TD CLASS="quote">Have a friend turn the key to the "on" position, while you lie on the ground with your ear as close to the fuel tank as possible. If you hear the hum of the pump, then you know that is not your problem.</TD></TR></TABLE>
why not pull out the back seat and listen to it. much safer. check your main relay
Old Apr 17, 2007 | 08:33 PM
ALL5tar's Avatar
Default Re: (fmrprojects)
ya, i can hear the hum from inside the car. I replaced the relay the other day.
noodlez1390
Jun 26, 2008 04:21 PM
DeadVet
Aug 10, 2005 07:50 PM
CXHatchback
Nov 23, 2004 11:32 AM
93egsi
20
Aug 26, 2003 02:54 AM
Accord15
Jun 25, 2003 09:54 AM
