Hood gap problem
Old Apr 14, 2007 | 12:44 PM
d'sb16a2's Avatar
Default Hood gap problem
I recently bout a 96 hatch with 99-00 conversion, and what really got to me was the hood gap, i believe that the hatch still has the 96 hood instead of the 99-00 hood, what do you guys think?
Old Apr 14, 2007 | 12:47 PM
.:Swig:.'s Avatar
Default Re: Hood gap problem (d'sb16a2)
try to move your hood lock mount
Old Apr 14, 2007 | 12:55 PM
si937's Avatar
I was dealing with the same problem. hours of adjusting it. I never got it to look flushed. I got the frontend for free when i bought my car. but thats the differents between oem and aftermarket.
Old Apr 14, 2007 | 01:05 PM
Riced-EL's Avatar
its a 99-00 hood for sure....96-98 has totally different headlight shapes...
Old Apr 14, 2007 | 01:06 PM
UCLA.lion's Avatar
I <3 My CB7.
Default Re: Hood gap problem (Takea$wigg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takea$wigg &raquo;</TD></TR><TR><TD CLASS="quote">try to move your hood lock mount</TD></TR></TABLE>
yep
just take off your grill, and they'll be 4 bolts holding your latch lock in place, loosen them and slide that sucker down.
it'll be a little harder to close your hood, have to pratically slam it to get it shut.
should work
also there are those little rubber mounts on the rad sport above the head light, that stops the hood from going down. You can adjust this by screwing them down further.
hope that works
Old Apr 14, 2007 | 04:02 PM
Markland Photo's Avatar
Default Re: (Riced-EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riced-EL &raquo;</TD></TR><TR><TD CLASS="quote">its a 99-00 hood for sure....96-98 has totally different headlight shapes...</TD></TR></TABLE>
i thought they were very similar?
Old Apr 14, 2007 | 04:05 PM
TicToc A*moto's Avatar
Default Re: (bulletspastsunset)
What you have sir is a 96-98 core support still on there. Replace it with a 99-00 one and you will be on your way to stardom!
Old Apr 14, 2007 | 04:49 PM
tha_badguy's Avatar
the core support doesnt affect the hood
only the bumper
is your front end aftermarket of oem?
Old Apr 14, 2007 | 08:20 PM
MidwestSiR's Avatar
Default Re: (tha_badguy)
I have an end all/solve all for you... GO BACK TO 96-98 FRONT.. that &gt; 99-00 any day
Old Apr 14, 2007 | 08:21 PM
Default Re: (MidwestSiR)
you still have a 96-98 hood
Old Apr 14, 2007 | 08:44 PM
cyb3rjak's Avatar
Default Re: (TicToc A*moto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TicToc A*moto &raquo;</TD></TR><TR><TD CLASS="quote">you still have a 96-98 hood</TD></TR></TABLE>
no thats a 99-00 hood. try twisting the two rubber stoppers at the front of the rad support to lower it. but it could also be that you latch is too high. good luck
Old Apr 15, 2007 | 10:38 AM
MidwestSiR's Avatar
Default Re: (cyb3rjak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyb3rjak &raquo;</TD></TR><TR><TD CLASS="quote">no thats a 99-00 hood. try twisting the two rubber stoppers at the front of the rad support to lower it. but it could also be that you latch is too high. good luck</TD></TR></TABLE>
how about you actually look at the pictures...? You can twist the rubber spacers all day but if he does that the hood will not match up to the fenders. The hood is in perfect position as are the fenders.. It's the core support.. the space is just the bumper/headlights not sitting on the support correctly.. OR the support is fucked up OR they're all non-oem parts..
We could all guess at what is wrong all day but we need some more details from the OP. Are there Honda Logos/part numbers on the parts? Was the car ever in a wreck? Are the fenders even lined up with the doors/A-pillars?!
crx_si-r
56
Feb 24, 2008 08:52 PM
lude98SH
Aug 16, 2006 08:28 PM
s1ngle
31
Jun 27, 2005 10:09 AM
jdmjeff
Jan 19, 2005 04:09 PM
Si Arn
Mar 22, 2004 08:36 PM
