ctr and itr cam
I personally have experience with the 99-01 j-spec ITR cam. I can tell you that there is a VERY noticeable difference. You will have to get adjustable timing gears though, because base timing on the j-spec ITR motor and the b16 are different, you will need to run the intake gear a few degrees off base to get it to run like you want to. Definitely the biggest bang for your buck bolt on, your b16 or b18 will feel like a completely different motor. HIGHLY recommended.
how would i be able to tell the difference between the itr cams and ctr cams. some guys is selling me itr cams for 300 for both. all i know thats difference is on the cams on one side there is a 1 lining on the itr and the ctr has two. he is also selling jhp cam gears for 140. is this a good deal??
go to this site, its a life saver
http://tiiite.b16a.com/FFmenu.htm
i bought my cams from a guy i didnt really trust and i compared it to the cams on the site and they were the real deal
