ctr and itr cams?
Can someone explain why to use a ctr intake cam and an itr exhaust cam?..........Starting a rebuild.......
[Modified by Weslay, 6:35 PM 11/21/2001]
[Modified by Weslay, 6:36 PM 11/21/2001]
ctr intake cam is slightly better than the itr intake cam, but the exhaust cams are the same.
better as in i think the lift/duration is a little more...therefore taking in more air.
Yup, 1fastGSR is right, there is a noticable difference if used in a b16a, because of the better rod ratio, it dwells longer at TDC taking advantage of the 3 degrees extra duration.
ITR
INTAKE lift - 11.5 mm, duration - 240 @ 1mm
EXHAUST lift - 10.5 mm, duration - 235 @ 1mm
CTR
INTAKE lift - 11.5mm, duration - 243 @ 1mm
CTR
