b16a3 swap in ek question.. SEARCHED!
theres a b16a3 swap (motor, tranny, axles, etc.) for sale locally that I want to put in my ek. my question is will the obd1 stuff work perfectly, or will i need to convert to obd2 (ie dizzy, injectors, or just the wiring harness). i read a couple archived threads, but its a different solution in every thread.
i already know that i'll need new mounts, but will the wiring harness and stuff be fine also? THANKS!
Modified by pnoyboldstar at 1:06 AM 4/12/2007
Convert to OBD2... since your car is OBD2 from the engine harness to the ECU plugs. You can then run a OBD2a to OBD1 conversion harness after that to run an OBD1 ECU.
put a OBD1 gsr into my 99dx. I ran a Si harness so i didn't have to wire up VTAK
the ecu adapter harness, (OBD2b to OBD1, and a OBD2b distributor pretty sure that's all you need. And just use a OBD1 ecu the goes with the B16a3
If it where me I would get a 96-98 ex harness, obd2 dizzy, and injectors. Use an obd2a jumper harness to convert it to obd1 and run the delsol ecu. everything should work fine.
Correct me if im rong
dont use a SI harness,99-00 haness are different, get a 96-98 civic harness find a OBD2 dizzy,injectors or cut the clip of the harness and add OBD1 clips and an OBD2 alternator or cut the clip and add an OBD1 clip then get a OBD2a to OBD1 jumper harness and run the OBD1 ECU....as far as mount all u need is a 00 SI reat T-bracket and driver side motor mount BRACKET(3 bolts holes to block) ...hope this helps
vtecftw
Aug 11, 2007 11:15 AM
FritzInTN
Jul 10, 2004 09:45 AM
