need help with turbocharged del sol
Old Apr 11, 2007 | 05:15 PM
barhonda_delsol's Avatar
Default need help with turbocharged del sol
hi im new here and this is my first post .i have 93 del sol d16a vtec with a t3/t4 turbo, 255 walboro fuel pump, fuel pressure regulator, jackson racing map controller, external wastegate, blow off valve, fmic, ect. stock distributer and plugs.
when boost hits it cuts out, could this be because of my spark plugs or anything with my ignition because i know its not the fuel cuting out. do i need an external distributer set up to advance my spark because i have one. please help
Old Apr 11, 2007 | 05:21 PM
Drifte's Avatar
sounds kinda like your blowing the spark out. idk what turbo hondas run for plug gap. hopefully you have an idea.
eg8tuner's Avatar
did you upgrade your injectors too
i can't see why you ignition would cut out under boost it might knock if the timing doesn't retard properly. what kind of pressures are you running
if its high enough you will probly need to upgrade but not on anything you would be doing with stick internals (at least not for long)
Old Apr 11, 2007 | 05:24 PM
Default Re: (eg8tuner)
stock injectors running 6psi
Old Apr 11, 2007 | 05:28 PM
evilsolb16's Avatar
Default Re: (barhonda_delsol)
you need new injectors and a good turn. stock injector are not good with boost. also dont go with a fmu they suck. just get some dsm blue tops and resistor box and have someone street/dyno tune it.
Old Apr 11, 2007 | 05:33 PM
Drifte's Avatar
how much boost?
what are you tuning with?
i may have some dsm injectors and resistor box for sale.
Old Apr 11, 2007 | 05:38 PM
Default Re: (Drifte)
running 6psi , tuning with?
Old Apr 11, 2007 | 05:42 PM
JKov240's Avatar
Please tell me you have SOME kind of tuning program...Hondata, Crome, Neptune, etc.
AT LEAST a piggyback
Old Apr 11, 2007 | 05:51 PM
Default Re: (JKov240)
no what do you suggest that i run
Old Apr 11, 2007 | 05:55 PM
would hondata s100 work good
Old Apr 11, 2007 | 06:06 PM
JKov240's Avatar
Honestly, you shouldn't be driving the car if it isn't tuned...how long have you been driving it untuned?
S100 is a good starting point, but if you got the paper then look at the S300
Old Apr 11, 2007 | 06:10 PM
just got it finished and drove twice around the town about 2 min drives. im 16 with my permant so cant drive it yet. right know its ripped apart and bieng repainted.
Scott4uf21
Apr 19, 2009 05:25 PM
Engage
20
Mar 29, 2009 07:49 PM
street sweeper
Sep 3, 2006 10:52 PM
94ta_lt1
Oct 28, 2004 10:17 AM
NkMike4
Jan 23, 2002 04:32 PM
