Why Doesn't my Radio Work?
Old Apr 11, 2007 | 04:49 PM
chris89's Avatar
Default Why Doesn't my Radio Work?
Ok, so the tip of my antenna was broken so i bought a basic universal antenna plugged it in and my radio still doesn't work. The stations show up on the headunit and when i Skip stations by holding the "next" tune button there's a beep that comes from the speakers. I don't get it? I used a cassette player and there was no audio, no music. This is the factory unit.
thanks
Old Apr 11, 2007 | 04:53 PM
JDM-EJ1's Avatar
Default Re: Why Doesn't my Radio Work? (chris89)
Since you hear the beep through the speakers, that would tell us that the speakers are functioning correctly. Try putting in a different radio (if it's OEM you'll need the code) and see what happens than.
Old Apr 11, 2007 | 04:57 PM
chris89's Avatar
Is this a common problem?
Old Apr 11, 2007 | 04:59 PM
chansaephanh's Avatar
im not sure if its common but i had the same problem. i just replaced my whole audio system
JDM-EJ1's Avatar
Default Re: (chris89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris89 &raquo;</TD></TR><TR><TD CLASS="quote">Is this a common problem?</TD></TR></TABLE>
I've never heard of it. But there is a first time for everything.
Old Apr 11, 2007 | 05:02 PM
qat727's Avatar
I had the same thing happen with one of my OEM decks. I just got a different OEM deck and it worked.
Oh, and one of the replacement decks I used developed the same type of problem on one channel after a while. I tore it apart and found a bunch of cold solder joints. I just gave up and got another OEM unit.
Old Apr 11, 2007 | 05:09 PM
chris89's Avatar
damnit, lol. my local junkyards have honda headunits, just no code! So, i guess i'll just get an aftermarket.
Old Apr 11, 2007 | 05:11 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris89 &raquo;</TD></TR><TR><TD CLASS="quote">damnit, lol. my local junkyards have honda headunits, just no code! So, i guess i'll just get an aftermarket.</TD></TR></TABLE>
This person here on Honda-Tech can help you get it; no charge.
https://honda-tech.com/zerothread/1886592
FilipinoChino
Honda CR-V & Element
Apr 21, 2014 01:48 PM
b0yg0tskills
Honda Civic (2001 - 2005)
Apr 30, 2007 04:34 PM
chris89
Audio / Security / Video
Apr 11, 2007 07:42 PM
initialvtec
Mar 14, 2005 03:16 PM
tdo
Dec 12, 2004 10:25 AM
