Vitara piston install question. Need opinions...
Old Apr 7, 2007 | 01:37 PM
Type-X's Avatar
Default Vitara piston install question. Need opinions...
I have vitara pistons and tuner toy rods. When I push in the wrip pins they go in as smooth as butter. Shouldn't there be some resistance. Wouldn't they slide left or right when installed. I'm afraid the pins might scratch my cylinder walls after the install. Anyone have any clue.
http://www.youtube.com/watch?v=wN32pW1xR7s
Old Apr 7, 2007 | 02:30 PM
seabass10369's Avatar
Default Re: Vitara piston install question. Need opinions... (Type-X)
vitara pistons are full floating so they should do that but there are to snap rings that hold the wrist pins in you should have those!
Old Apr 7, 2007 | 09:19 PM
maynards_ek's Avatar
Default Re: Vitara piston install question. Need opinions... (seabass10369)
My pins were the opposite. Had to leave them in the freezer overnight to fit them. (hope that doesn't mean a problem down the road) The only difference in my setup is that I used eagle h-beams.
Old Apr 7, 2007 | 09:21 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: Vitara piston install question. Need opinions... (maynards_ek)
uhhhhhhhhhhhhhhhhhhh dude you have the wrong wrist pin!!!!!!! they should be pressed in most of the time, not to mention those pistons knck, anyways you are missing 2 snap rings
Old Apr 7, 2007 | 09:23 PM
* B A N N E D *
Default Re: Vitara piston install question. Need opinions... (spork motorsports)
http://store.summitracing.com/...w=sku
Old Apr 7, 2007 | 09:32 PM
Why do people keep insisting that vitaras knock? Yes, there is a little piston slap, but it disappears after the engine is warm and oil is circulating. I was skeptical of them until I actually saw (and rode in) a car with them installed. He has been running them since may of last year and is yet to have a problem. (387hp) I chose vitaras as a cost effective alternative to brand-name forged pistons. They are loud at first, but any worries disappear when you lean on the go pedal.
Old Apr 7, 2007 | 09:52 PM
* B A N N E D *
still a little bit of piston slap is bad, it will get worse over time, just like a motor that knocks now a little and will eventually get worse
Old Apr 7, 2007 | 10:00 PM
turboekcivic's Avatar
when and where did you get your rods form?
Old Apr 7, 2007 | 10:07 PM
Default Re: Vitara piston install question. Need opinions... (turboekcivic)
Who?
Old Apr 7, 2007 | 10:15 PM
Type-X's Avatar
Thanks for the replies but I found the locks that keep the pin from sliding like that. Yeah these are really for budget builders but if tuned right, these babies can make alot of power. Brand new for $50, who woudn't buy them.
Old May 10, 2007 | 09:38 AM
JST1CAM's Avatar
where did you get them brand new for 50 bucks?
Old May 21, 2007 | 12:33 PM
joppe's Avatar
What is vitaras piston to wall clearance, im gonna put .20 oversize, so need to know clearance. Does pistons include spec sheet?
BigMike0147
May 24, 2011 09:38 AM
turboman2.2
Feb 12, 2010 12:43 PM
Nichelson_Performance
Jun 30, 2009 03:44 PM
crxrider07
Mar 14, 2009 10:44 AM
11psiTurboSI
Jan 1, 2004 11:19 AM
