need help fan running while car off
ok here's the problem yesterday my neighbor told me that the car was making a sound almost all day. but i was too busy to check and when i do at night the fan was running with the car off. so went out and when i get back the battery is complete dead. what can be the reason the fan was running like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee »</TD></TR><TR><TD CLASS="quote">fan switch short, </TD></TR></TABLE>
yea on/off switch for your fan would seem like a good solution. that way when your driving your fan will be on all the time so things stay cooler. OR you can run an on/off switch for your battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si »</TD></TR><TR><TD CLASS="quote">
yea on/off switch for your fan would seem like a good solution. that way when your driving your fan will be on all the time so things stay cooler. OR you can run an on/off switch for your battery.</TD></TR></TABLE>
Did you even read the post? His fan is staying on when the car is OFF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanuckCRX »</TD></TR><TR><TD CLASS="quote">Did you even read the post? His fan is staying on when the car is OFF.</TD></TR></TABLE>
yea so when his car is OFF, he can turn his switch to the OFF position for his fan. am i missing something?
ok when i disconnect the green plug next to the fan and radiator the fan turns off and if i just lightly put the plugs together it turns back on so what could it be the cooling fan switch?
mike93eh2
13
Feb 17, 2007 04:23 PM
