tsx retrofit?
okay i saw a guy selling these projecters online here for 100 just the projecters. i was wondering what else do i need to make it work. do i just need to buy the hid kit and it will plug and play when i install the tsx projecters in my headlight?
You will need a "kit" (really just capsules and ballasts) that includes D2S HID capsules, and then everything should more or less be plug-and-play once you get the projectors installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nh0nie »</TD></TR><TR><TD CLASS="quote">if you are going to get tsx projectors you might want to get BMW shrouds then if you were to get HID you have to get D2S HID...</TD></TR></TABLE>
waht you guys mean by d2s? i dont know much about hid.
Wrong!
If you wanna lose your hi beams then a tsx retrofit is your choice. But for that u'd need D2S (philips 85122) bulbs, D2S Ballast, shrouds, complete H4 harness or a bixenon harness if you wanna go with bixenon projectors which are the maxima e55's, mercedez or bmw e46's, acura tl, infinity G35(06+), FX or Murano bixenon projectors, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 »</TD></TR><TR><TD CLASS="quote">Wrong!</TD></TR></TABLE>
Are you replying to me? Not a single thing that I wrote in this thread is incorrect.
If you're referring to wiring, he didn't ask about it (at least that's not how I interpreted his question). He seemed to be asking about what would be needed to get the setup physically installed in his headlight housings.
However, I'd strongly recommend using a relay setup rather than an adapter harness. If you're capable of retrofitting HID projectors into your halogen housings, you should certainly capable of connecting the wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Are you replying to me? Not a single thing that I wrote in this thread is incorrect. </TD></TR></TABLE>
Everything you said is right, just that he added a couple things that you would "need" to complete a retrofit (upgraded harness, shrouds, etc)
BobGnarly
Feb 1, 2005 05:38 PM
