iac
Old Apr 3, 2007 | 08:52 PM
tbuck23's Avatar
Default iac
i have a question how do u know if your iac is dead because when u start my car the rpm just go to 2000 and stay there we have try everything. help pz
Old Apr 4, 2007 | 01:13 PM
devnull's Avatar
Sounds like a vacumm leak. If the IAC is dead it can cause that, however more likely the engine will have problems staying alive.
Old Apr 4, 2007 | 08:05 PM
hondamanwill's Avatar
did you unplug it? if so did the idle go down? Is the cable to tight? can of carb cleaner to check for vac leaks
Old Apr 5, 2007 | 08:15 AM
EE_Chris's Avatar
Default Re: (hondamanwill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanwill &raquo;</TD></TR><TR><TD CLASS="quote">Is the cable to tight?</TD></TR></TABLE>
If the motor is warmed up and the idle just sticks at 2k rpm, I'd look at the throttle cable too (or the throttle plate stop screw being way out of adjustment and holding open the throttle plate more than it should).
Old Apr 5, 2007 | 03:52 PM
base-op.1320's Avatar
Default Re: (EE_Chris)
There should be some little holes in the throttle body by the butterfly - try plugging them with your finger and see how it idles
Old Apr 5, 2007 | 05:00 PM
integratee's Avatar
Default Re: (base-op.1320)
If your RPMs bounce around a bit (2k-whatever) make sue the IAv is properly plug in by checking the color code. It may be the throotle bable that needs re-alignment, or It could be that the throttle body is open a bit: adjust 2 screws 1) at the top, w a flat head screw driver 2) twourds the botttom where throttle cable mounts on, you wil need a small alan key, and a 8mm i think.... check it out good luck
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
cdmef
Jul 3, 2011 06:03 AM
graphic
Oct 23, 2003 06:35 PM
stock97
Aug 14, 2003 10:14 PM
eknine
Jul 10, 2003 08:36 AM
