adjusting throttle cable????
Old Oct 23, 2003 | 11:13 AM
graphic's Avatar
Default adjusting throttle cable????
i have a 5thgen and my idle is fine but my throttle cable shows more than a 1/2in of play...
i want to tighten it...but will this affect idle...being that the 5thgen has a seperate idle adjusment screw???
Old Oct 23, 2003 | 12:13 PM
19924ws's Avatar
No it is shut all the time unless the cable holds or pulls the throttle body plate open.
Old Oct 23, 2003 | 12:58 PM
graphic's Avatar
Default Re: (19924ws)
no...idle won't be affected???
or no..i don't need to adjust???
Old Oct 23, 2003 | 01:34 PM
spoolinlude's Avatar
I live under a rock
Default Re: (graphic)
No idle won't be affected as long as you don't tighten it up too much..... the throttle return spring holds the plate closed until you step on the gas
Old Oct 23, 2003 | 06:35 PM
19924ws's Avatar
Default Re: (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">No idle won't be affected as long as you don't tighten it up too much..... the throttle return spring holds the plate closed until you step on the gas</TD></TR></TABLE>
What he said
cdmef
Jul 3, 2011 06:03 AM
nemesiskrp
Apr 20, 2009 08:43 PM
tbuck23
Apr 5, 2007 05:00 PM
efyou
Apr 28, 2006 09:40 AM
stock97
Aug 14, 2003 10:14 PM
