Car Still Runs like crap PLEASE HELP
Old Apr 3, 2007 | 06:36 PM
Crazy4Honda's Avatar
Default Car Still Runs like crap PLEASE HELP
Ok i have done alot of searching and haven't found and answers, car is really doggy in any gear replaced pcv valve both o2s are new??? what else??
The car is a 98 EK y5 bottom end y8 top end I/H/E i didnt do the mini me, Could someone have done it wrong??? PLEASE RESPOND I NEED TO GET THIS FIXED
Car Had ALOT of power and now nothing
Old Apr 3, 2007 | 07:30 PM
NVMYSTI's Avatar
Default Re: Car Still Runs like crap PLEASE HELP (Crazy4Honda)
Have you changed the sparkplugs, plug wires, distributor cap n rotor, and fuel filter or check the condition of those items?
Old Apr 3, 2007 | 07:44 PM
turboguy84's Avatar
Default Re: Car Still Runs like crap PLEASE HELP (NVMYSTI)
Vtec may not be working, also could have slipped a tooth on timing, dirty or fouled plugs, clogged cat??
Old Apr 3, 2007 | 07:58 PM
94hondacivicvtec's Avatar
Default Re: Car Still Runs like crap PLEASE HELP (johndoe2229)
you can also play with the timing a little through the disr. but do that after the sparkplugs, plug wires, distributor cap n rotor, and fuel filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johndoe2229 &raquo;</TD></TR><TR><TD CLASS="quote">It might be your muffler blow in valve for cars horsepower, Install universal muffler for double horsepower output.</TD></TR></TABLE>
can someone ban this guy?
Old Apr 3, 2007 | 08:03 PM
maynards_ek's Avatar
Default Re: Car Still Runs like crap PLEASE HELP (94hondacivicvtec)
x2 on the timing belt jumping a tooth. I would also double check your ignition components and replace the fuel filter. Bad gas is also a possibility.
Old Apr 3, 2007 | 08:08 PM
Default Re: Car Still Runs like crap PLEASE HELP (maynards_ek)
i have replaced plugs wires fuel filter and the cat is new but i guess it can still be clogged and the distributor is stock but wouldnt that make the car miss and chugg ??
Old Apr 3, 2007 | 09:28 PM
sol2hatch's Avatar
first, you need to give us more info. When did it start doing this? Was it working fine, and then something happened? Has it not run right since the Minime was done, is it throwing any codes, did you pull them? ETC ETC ETC
Old Apr 3, 2007 | 09:29 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Car Still Runs like crap PLEASE HELP (sol2hatch)
Old Apr 3, 2007 | 09:32 PM
mdog244's Avatar
Default Re: Car Still Runs like crap PLEASE HELP (ek forever guy)
LMAO x2
Bruce_Leroy__
Oct 16, 2011 10:53 PM
admess188
Aug 13, 2011 07:29 PM
Jonknee
Sep 5, 2006 04:10 PM
RiCE On IcE 2
Mar 29, 2006 09:40 AM
rice a roni
Mar 23, 2006 12:37 PM
