What is wrong?
Old Mar 28, 2006 | 11:43 AM
RiCE On IcE 2's Avatar
Default What is wrong?
I'm not sure whats wrong but when I am in the post VTEC RPM's my car seems to bog. I think vtec is engaging but tough to tell on the stock filter. But the climb after 5800 RPM is not smooth anymore. It will even seem like is bogs sometimes at 7k. The motor is stock except my icebox which right now is jsut running my stock filter. Could it be the spark plugs, ECU or oil? My car is a 00 with 98K on the odo.
Old Mar 28, 2006 | 12:13 PM
Haleiwa-Brando's Avatar
Default Re: What is wrong? (RiCE On IcE 2)
I would suggest doing all your standard maintanence.
Change the fuel filter, plugs, plug wires, distributor cap, distributor rotor, check and/or replace all the fluids, check/replace the battery, check all your grounds. Oh...your not throwing any codes are you?
Old Mar 28, 2006 | 12:40 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: What is wrong? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">I would suggest doing all your standard maintanence.
Change the fuel filter, plugs, plug wires, distributor cap, distributor rotor, check and/or replace all the fluids, check/replace the battery, check all your grounds. Oh...your not throwing any codes are you?</TD></TR></TABLE>
x2
Old Mar 28, 2006 | 02:16 PM
Default Re: What is wrong? (walker111)
the codes should produce a cehck engine light right?
Old Mar 28, 2006 | 02:23 PM
white rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">the codes should produce a cehck engine light right?</TD></TR></TABLE>
Correct.
x3 on Surferboy's suggestion
Old Mar 29, 2006 | 08:08 AM
Default Re: What is wrong? (white rocket)
could the above mentioned things cause a back fire too?
Old Mar 29, 2006 | 08:30 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Change the fuel filter</TD></TR></TABLE>
Old Mar 29, 2006 | 09:40 AM
JjuuN R's Avatar
definately do normal maintinence on your car, it'll feel brand new.
i recently had the problem of my T-Stat staying stuck open and letting too much coolant in resulting in my temps not getting up to where they should be for maximum performance (VTEC) changing that, the plugs, chaninging the oil made it feel like a whole new beast. spinning the tires when hitting VTEC in 2nd and 3rd, i love it
saintbhts
Aug 7, 2014 11:22 PM
VTECdTypS
Sep 22, 2005 03:25 PM
darkside3000
Jan 23, 2005 02:17 PM
90SiHatchbk
May 24, 2004 07:31 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
