Idle Problem
Old Apr 3, 2007 | 08:47 AM
kevoweb's Avatar
Default Idle Problem
After my car is warmed up, the idle drops to about 500. When it does this the car starts to shake quite a bit, especially the steering wheel. I'm not sure what's going on here. I've done sparkplugs, cap, rotor, plug wires, cleaned the k&n filter, change oil regularly. Not getting any CELs. I've searched and seen that the IAC may be the problem. My question is where is it located on the d15b7?
Also, i don't believe this has anything to do with that problem, but i just finished converting my car from auto to manual and now my tach reads 0-100 rpm when the car is idling.
Any help is greatly appreciated.
Old Apr 3, 2007 | 08:53 AM
vi3tromanc3r's Avatar
Default Re: Idle Problem (kevoweb)
my car idles at 500-600 but i got a d16z6. sounds normal to me. mines doesnt shake that much. u can always adjust the idle IAC i believe is behind the TB and ders a little screw you turn.
Old Apr 3, 2007 | 09:17 AM
kevoweb's Avatar
Default Re: Idle Problem (vi3tromanc3r)
i believe the idle is normal, but i don't think the shaking is normal.
Old Apr 3, 2007 | 09:27 AM
Jamied's Avatar
you should be idling around 700...
just turn ur idle up a tad
Old Apr 3, 2007 | 11:13 AM
kevoweb's Avatar
Default Re: (Jamied)
ok, i'll give it a try. any other thoughts?
Old Apr 3, 2007 | 12:30 PM
P a r i s h's Avatar
i have the same exact problem in my boosted b16.I was told its either the iac or fitv.
Old Apr 3, 2007 | 12:35 PM
Smurf4JDM's Avatar
reser ecu
Old Apr 3, 2007 | 12:37 PM
ghettoSi's Avatar
she's cheating on you
Default Re: (Smurf4JDM)
Its either your IACV or you need to adjust your throttle cable so that the throttle body is open a tad more
Old Apr 3, 2007 | 01:03 PM
EK tommy's Avatar
Default Re: (ghettoSi)
my car was doing the samething all i did was clean the TB. with TB cleaner. it worked for me.
Old Apr 3, 2007 | 01:07 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettoSi &raquo;</TD></TR><TR><TD CLASS="quote">Its either your IACV or you need to adjust your throttle cable so that the throttle body is open a tad more</TD></TR></TABLE>
i was going to suggest the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r &raquo;</TD></TR><TR><TD CLASS="quote">my car idles at 500-600 but i got a d16z6. sounds normal to me. mines doesnt shake that much. u can always adjust the idle IAC i believe is behind the TB and ders a little screw you turn. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jamied &raquo;</TD></TR><TR><TD CLASS="quote">you should be idling around 700...
just turn ur idle up a tad</TD></TR></TABLE>
i used to do this until recently i spoke to a handa technician. and in speaking with him, he told me you should never have to touch the idle adjust screw.
Old Apr 3, 2007 | 02:13 PM
kevoweb's Avatar
Default Re: (philosofy1)
thanks guys for the responses!
so what i'm gathering is to clean the throttle body? or adjust the throttle cable? Can i tell if the throttle body needs cleaned if i remove the intake? or do i need to remove the thottle body as a whole to see?
PhatwhipsJDMkits
11
Apr 7, 2009 05:51 PM
longshot
Nov 30, 2008 10:44 AM
ic89
Oct 16, 2006 05:38 PM
KNIVES
Apr 5, 2004 09:17 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
