Is this true?
Old Mar 29, 2007 | 08:14 PM
Civic Hybrid's Avatar
Default Is this true?
So I was going to through on a JDM ITR intake manifold on my b16 but then recently got word that since I don't have internals the intake manifold might make me lose power or also might not make any power gains at all. Is this true? Should I hold off on throwing it on until I buy internals?
Old Mar 29, 2007 | 08:18 PM
ek2k's Avatar
Default Re: Is this true? (Civic Hybrid)
Never heard of this... The ITR manifold should give you some gains...but of course you won't get all you can out of if your stock.
If I'm wrong someone please correct me...
Old Mar 29, 2007 | 08:23 PM
Default Re: Is this true? (ek2k)
Yeah I had never heard of it either. I mean I'm not expecting mad power but I wasn't expecting to lose power.
UncleD's Avatar
The only place the type r manifold will gain you is from 7k and up. The P30 has been dyno'd against it on B16's and actually beats it by a fair margin until the upper r's. However, if you have cams and a good header to back everything up, do the r.
Old Mar 29, 2007 | 09:12 PM
Default Re: Is this true? (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">The only place the type r manifold will gain you is from 7k and up. The P30 has been dyno'd against it on B16's and actually beats it by a fair margin until the upper r's. However, if you have cams and a good header to back everything up, do the r.</TD></TR></TABLE>
Well I was planning on buying stage ones from skunk and the header on the car right now is a JDM ITR. So I guess the question is....is it smarter to just hold off until i buy cams?
Old Mar 29, 2007 | 10:09 PM
sauceja's Avatar
I like my ITR IM just because it looks sexy as hell.
You can buy my p30 manifold for now to hold you off.
Otherwise I would put the ITR manifold on just cause you would have to buy another gasket to swap it out later. or buy a hondata IM gasket.
Old Mar 29, 2007 | 10:16 PM
96Spec Ek's Avatar
exactly
Old Mar 30, 2007 | 03:34 AM
1.8L_allmotormilitia's Avatar
usually i run upgraded manifold ITR/BLOX/SKUNK2 w/ bigger throttle body when i put cams in. other then that i don't bother touching it....thats just me.
Old Mar 30, 2007 | 04:48 AM
Default Re: Is this true? (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">I like my ITR IM just because it looks sexy as hell.
Otherwise I would put the ITR manifold on just cause you would have to buy another gasket to swap it out later. or buy a hondata IM gasket.</TD></TR></TABLE>
I still have my stock manifold on the car still. I also did buy the hondata IM gasket.
Old Mar 30, 2007 | 04:50 AM
Default Re: (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">usually i run upgraded manifold ITR/BLOX/SKUNK2 w/ bigger throttle body when i put cams in. other then that i don't bother touching it....thats just me.</TD></TR></TABLE>
I have the ITR throttle body on it as well.......so your sayin leave it alone until I throw some cams in it.
Old Mar 30, 2007 | 05:51 AM
Default Re: (Civic Hybrid)
Any more thoughts welcome!
hectic57
Mar 6, 2008 06:06 AM
turbo boost
Sep 28, 2006 06:03 AM
Maxboost00
11
Feb 7, 2005 11:57 AM
jdmjeff
17
Jan 13, 2005 03:57 PM
Sassafrass
Nov 5, 2004 11:43 PM
