Turbo Manifold- cant not enough space to put on all the nuts...
Old Mar 29, 2007 | 07:13 AM
vestalfootball72
Guest
Posts: n/a
Default Turbo Manifold- cant not enough space to put on all the nuts...
Just as the title says, there isnt enough room to put the nuts onto the studs for my turbo manifold to bolt onto the head. Im using a really thick gasket, anyone think it would be alright to skip out on one of them?
Old Mar 29, 2007 | 07:24 AM
92redhatch's Avatar
i had to take out my studs and use bolts. i recomend you do that for the nut that doesnt fit.
93supercoupe's Avatar
Default Re: Turbo Manifold- cant not enough space to put on all the nuts... (vestalfootball72)
u have to have them all loose so u can pul the manifold out and go in AS ur tightting the tight ones, or ur beat and bought a **** mani
Old Mar 29, 2007 | 09:32 AM
vestalfootball72
Guest
Posts: n/a
Default Re: Turbo Manifold- cant not enough space to put on all the nuts... (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">u have to have them all loose so u can pul the manifold out and go in AS ur tightting the tight ones, or ur beat and bought a **** mani </TD></TR></TABLE>
gonna try that... good idea!
Old Mar 29, 2007 | 10:35 AM
katoeh2o's Avatar
Default Re: (92redhatch)
or you can use longer studs, I had to do that cause my first manifold had a super thick head flange and very little clearance for bolts.
Old Mar 29, 2007 | 06:04 PM
1Bar GSR's Avatar
Default Re: (katoeh2o)
Right! You have to just barely put the manifold on and then as the manifold goes on tighten the hard to get to nuts. Im guessing you have ram horn and your trying to get the nuts on the sides?
Old Mar 30, 2007 | 08:31 AM
vestalfootball72
Guest
Posts: n/a
Default Re: (1Bar GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Right! You have to just barely put the manifold on and then as the manifold goes on tighten the hard to get to nuts. Im guessing you have ram horn and your trying to get the nuts on the sides?</TD></TR></TABLE>
got it- just had to do the two ones that i coudlnt get first, then push the manifold in and do the rest- Im using M8 1.25 pitch 20mm long SS grade 8.8 bolts for a few of them- they work great!
BongoBennie
Engine Machining & Assembly
Jan 29, 2017 07:50 PM
Charlie Moua
Nov 22, 2010 04:44 PM
redboost10
Jan 22, 2004 08:06 PM
GDM Z28
Dec 28, 2003 09:04 PM
romeo619romeo
Feb 27, 2003 08:40 AM
