K&N air filter for turbo, what model do you use that flows enough?
I called Precision today and they said I would need an air filter that could flow 68 lb/min. So I went to K&N's site and found that a turbo that fits in my setup(Mini-me manifold, Bseries, EG) only flows around 450 cfm when I need around 850 cfm...
What filters are you guys using ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">i think its just all the same depending on what size and design you prefer</TD></TR></TABLE>
Not if it restricts the turbo though...
Anymore people know what part number they are running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict »</TD></TR><TR><TD CLASS="quote">I've got the RU2580, I believe that's it directly on te compressor housing on my 30r, works great
Same here
</TD></TR></TABLE>Same here
http://store.summitracing.com/...-2580
That thing is tiny...
2" inlet
I need a 3" inlet
http://store.summitracing.com/...-2820
This looks better as long as I have 6.5" available. I'll have to measure
2" inlet
I need a 3" inlet
Full-Race Stage2GT with AC - aka very little clearance.
It is a tight fit behind my PWR radiator but I had an aluminum peice built to allow me to fit this filter. One thing I noticed is that it had the hole in the top, guess that is for extra air flow? K&N also sells one that is the same dimensions but with two holes.
http://www.knfilters.com/searc...-5121
*EDIT* Disregard first post. I think my brother was mistaken as to which filter I was using.
Modified by sp00led at 1:17 PM 4/3/2007
Modified by sp00led at 1:18 PM 4/3/2007
not to jack the thread, but has anyone used the filter that comes on AEM Short ram or cold air intakes? I thought about using my short ram, cutting it up and using it as the intake to the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 »</TD></TR><TR><TD CLASS="quote">not to jack the thread, but has anyone used the filter that comes on AEM Short ram or cold air intakes? I thought about using my short ram, cutting it up and using it as the intake to the turbo.
waht do you think i'm doing?? the post right above yours
</TD></TR></TABLE>waht do you think i'm doing?? the post right above yours
ICeDoUt
24
Apr 6, 2006 09:48 AM
civel
Jan 23, 2006 09:00 AM
