What air filers are you guy's running on your turbo's
What air filters are you guy's running on your turbo's
im just curious
i ve started building up my turbo kit and one thing i was thinking what air filter to use. i seen some k&n filters all bent, like getting sucked in the turbine. i also seen those spong honeycomb ones. then ive seen just a plain screen but thats out of the question, roads around here are messed up..
please post what air filter your running and do you clean it. if so how offten. or do you just buy a new one. i really dont want to have a shitty air filter and chance screwing up my seals
Re: What air filters are you guy's running on your turbo's (civel)
i guess no one on this site use's and air filter on there turbo??? or maybe no one wants to answer because im so called a newb
I got a 1000hp K&N on my SC50...I havent had anything else to compare to, other than not having one on...
Re: What air filters are you guy's running on your turbo's (mrlegoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman »</TD></TR><TR><TD CLASS="quote">I use the APEXi Power Intake:
same here..8)
same here..8)
Re: What air filters are you guy's running on your turbo's (mRek9R)
is it worth the $90?
i'm running a 3" hks style mushroom foam filter.
works great and is small so its easy to fit in tight places
Re: What air filters are you guy's running on your turbo's (EF8opey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey »</TD></TR><TR><TD CLASS="quote">is it worth the $90?</TD></TR></TABLE>
Well i know that over all shape has been dyno proven to be the most efficient (w/o filter, the gradual curving towards the center 'horn' shape) so im sure that this type of design would prove its self versus just a normal cone filter.
But of course its just speculation coming from me.
Re: (zexifiedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude »</TD></TR><TR><TD CLASS="quote">one more for the apexi filter</TD></TR></TABLE>
is it really that good. just need to justify to myself spending $90 on a filter
Re: What air filters are you guy's running on your turbo's (Pay2play killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pay2play killa »</TD></TR><TR><TD CLASS="quote">i'm running a 3" hks style mushroom foam filter.
works great and is small so its easy to fit in tight places</TD></TR></TABLE>
they have the hks style (replica) of the mushroom? or are you talking about the real one?
i had a hks mushroom on my turbo..hit the 2 step and it sucked it in.....so new turbo and no filter
Re: What air filters are you guy's running on your turbo's (cubish)
Not the best filter in the world, but all i had on my 60-1 turbo was a piece of screen from ace hardware with a big hose clamp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish »</TD></TR><TR><TD CLASS="quote">i had a hks mushroom on my turbo..hit the 2 step and it sucked it in.....so new turbo and no filter</TD></TR></TABLE>
how the hell that happen? I read in another post also. thats strange
the HKS filter has a skeleton frame with a velocity stack design and then the foam and then the grill over the foam. so the foam is sandwich between the frame and the grill. no way to suck it in. unless you are using the immitation ones off ebay that only have the foam and grill.
but to be safe I a mesh and and put it before the filter in case it happen to mine
Re: (zexifiedlude)
Re: (FredoSP)
Re: What air filters are you guy's running on your turbo's (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">
but to be safe I a mesh and and put it before the filter in case it happen to mine</TD></TR></TABLE>
def wasnt a knock off...and it def sucked in part of the filter element...i have a torn up compressor wheel on my desk to prove it...
