crx conversion
Old Mar 28, 2007 | 03:53 AM
sean-sports's Avatar
Default crx conversion
i just bought a crx automatic and i would like to change it to stick can anyone tell me what i need and who to swap it over
Old Mar 28, 2007 | 04:40 AM
SIRX's Avatar
Default Re: crx conversion (the blurr)
Your search for tranny swap returned 106 results
and that was just basic search!!!
Old Mar 28, 2007 | 06:05 AM
steveo135's Avatar
Default Re: crx conversion (SIRX)
Originally Posted by higgunscrx
Engine & Transmission
https://honda-tech.com/zerothread?id=1193782 - b16a crx si swap guide
https://honda-tech.com/zerothread?id=1052937 - 1988 and 1991 Si vacuum diagram
https://honda-tech.com/zerothread?id=1325930 - Changing transmission fluid,Lubricating speedometer cable and
reconnection of cable at the transmission
https://honda-tech.com/zerothread?id=1360901 - Honda Engine Code Chart
https://honda-tech.com/zerothread?id=335078 – Spades Huge SOHC Upgrades Thread
https://honda-tech.com/zerothread?id=382416 - B Series Axle Replacement
https://honda-tech.com/zerothread?id=596873 – D Series Transmission Disassembly and Input Shaft
https://honda-tech.com/zerothread?id=864710 – SOHC Camshaft and Valve Springs Install
https://honda-tech.com/zerothread?id=363047 – VTEC Cams Comparison
https://honda-tech.com/zerothread?id=684550 – H22 vs B Series Weight
https://honda-tech.com/zerothread?id=682485 – Engine Compression Ratio Formulas
https://honda-tech.com/zerothread?id=694733 – Civic Chassis Codes
https://honda-tech.com/zerothread?id=466327 – Removing Engine Without Hoist
https://honda-tech.com/zerothread?id=1263692 - how-to install a Walbro HP 255 lph fuel pump into a CRX
https://honda-tech.com/zerothread?id=1230434 - B&M Fuel pressure modifier install How-To
https://honda-tech.com/zerothread?id=1157746 - EF CRX/Hatch B series turbo shopping list (BlueShadow's turbo project)
http://allmotorhonda.com/techp...s.htm - B series tranny specs
http://web.archive.org/web/200...s.htm - Great axle info that no longer exist unless using the right website
http://coreyonline.tripod.com/crxmainpage.html - B16 swap into first generation CRX
http://www.geocities.com/senpa....html - D16A6 / D16Y8 mini-me
http://www.geocities.com/senpa....html - Transmission Removal
http://www.geocities.com/senpa....html - Clutch Install
http://www.angelfire.com/ca/Dr....html - B16 Dizzy diy repair
http://www.geocities.com/neonradiator/neon.html - Dodge Neon Radiator upgrade (yes the neon is good for something)
http://www.c-speedracing.com/h...m.php - DOHC cam swap how-to
https://honda-tech.com/zerothread?id=953151 - B series Torque Specs List
https://honda-tech.com/zerothread?id=953089 - shopping list of nuts, bolts, and other stuff needed for the swap
https://honda-tech.com/zerothread?id=939636 - Removing D-Series Transmissions in CRXs'
https://honda-tech.com/zerothread?id=945557 - where everything plugs into the motor on a MPFI harness
https://honda-tech.com/zerothread?id=427814 - SOHC Cam Specs
http://crx.honda-perf.org/arti....html - Mini-me engine theory
http://www.knology.net/~jediklc/D.htm - Compression calculator
https://honda-tech.com/zerothread?id=699787 - How to fix a FITV its as easy as 1, 2, 3
https://honda-tech.com/zerothread?id=750674 - installation of camshaft into a sohc
http://www.angelfire.com/on4/crxpage/shift.html - Fixing Sloppy Shifting in Transmission
https://honda-tech.com/zerothread?id=555929 - LS 5th Gear Install Guide JDM B16 S1
https://honda-tech.com/zerothread?id=90743 - Camshaft Test
https://honda-tech.com/zerothread?id=382416 - Axel Replacement
http://tjshondas.20m.com/l3.htm - ZC L3 Transmission Information
https://honda-tech.com/zerothread?id=335078 - SOHC Upgrades (Ongoing Information)
http://www.angelfire.com/d20/h....html - DPFI to MPFI Fuel Injector Swap Guide #1
http://www.geocities.com/teampimports/fuelinj.html - DPFI to MPFI Fuel Injector Swap Guide #2
http://www.geocities.com/c_rexboy/mpfi.html - DPFI to MPFI Fuel Injector Swap Guide #3
http://www.bladesilver.net/crx/projects.html - DPFI to MPFI Fuel Injector Swap Guide #4
http://www.fourthgenhatch.com/mpfi.html - DPFI to MPFI Fuel Injector Swap Guide #5
https://honda-tech.com/zerothread?id=404493&page=1 - B16A Secondary o2 Sensor Wiring and Vacuum Diagrams
http://www.geocities.com/bing_bong916/vtec.html - More Information On Swapping D16Z6 into an EF
http://crx.honda-perf.org/arti....html - How to Swap a Z6 Head Onto Your A6
http://b16a.honda-perf.org/theswap.html - JDM B16A Information and 4th Generation ECU Pin Outs
https://honda-tech.com/zerothread?id=717258 - B16 Swap info
https://honda-tech.com/zerothread?id=692814 - LSD....toss your tapered bearings and install the ball bearings, no preload
https://honda-tech.com/zerothread?id=177711#1593432 - Sonnys compression spreadsheet
http://www.norcalcrx.org/dropp...p.htm - B16 Install Info (Thanks Ryan Droppedcrxsi)
http://www.thezcr.com/forums/a...=1137 - Si to Zc Wiring Diagram
http://thenew.gamesbbs.com/~dmoore/zc.htm - Zc Swap Info
http://thezcr.com/forums/ - Alot of Zc Info
https://honda-tech.com/zerothread?id=1108908 - Abit of H22 Info
http://sportcompactcarweb.com/...ifter/ - H22 Shifter into Crx
The N1 CTR pulley uses a 4 rib 735mm belt. A 92-94 Acura Vigor power steering belt fits, part number 56992-PV0-013
A 90 Civic DX tranny weighs 68 lbs
Modified by higgunscrx at 8:48 PM 6/10/2006
Modified by higgunscrx at 7:04 PM 9/3/2006
FAQ is a good place to start! search b4 u post questions about such covered topics like this
moobthoj707
Jun 4, 2010 12:59 AM
ef89
Apr 28, 2009 12:50 PM
ramiel2000
May 17, 2008 08:47 PM
duk1
Oct 13, 2007 03:45 PM
Garrett
Sep 24, 2004 08:34 AM
