tuning idle?
Old Mar 27, 2007 | 08:23 PM
94typeR's Avatar
Default tuning idle?
does afr affect idle?
before tuning, i was lean and idled around 800 constantly.
after tuning, im around stoich and idle drops to around 650-700. this is too low for my comfort.
does the afr have anything to do with the idle drop? can the idle rpm be raised in the tune while keeping the same afr?
Old Mar 27, 2007 | 08:30 PM
Luserkid's Avatar
Default Re: tuning idle? (EH2typeR)
a/f will effect the idle. 650-700 is a good idle.
Old Mar 27, 2007 | 08:46 PM
bigbadboy's Avatar
tighting up your throttle cable and set the idle to wat ever you want. easy fix
Old Mar 27, 2007 | 08:47 PM
GetawayInMoscow's Avatar
Default Re: (bigbadboy)
what EMS are you using? don't listen to everyone else in the post they don't know what they are talking about
Old Mar 28, 2007 | 02:44 AM
94typeR's Avatar
Default Re: (GetawayInMoscow)
using crome
if i remember correctly, theres a option on crome for target idle
is this what should be edited?
has nothing to with the throttle cable. only thing that changed was the tune.
Modified by EH2typeR at 7:01 AM 3/28/2007
Old Mar 28, 2007 | 05:48 AM
Default Re: (EH2typeR)
Yeah crome's target idle sometimes works and sometimes doesn't. I have mine set at 1000 and my car idles perfectly at 1100, lol.
Try playing with that though. Set it to 850 or 950 and see how you like it.
Old Mar 28, 2007 | 05:49 AM
Also if you have big *** cams (like skunk2 pro series) try bumping up the timing at idle, like to 21* or 22*.
turbohatch96y7
Engine Management and Tuning
Jun 10, 2013 07:42 AM
Arthas
Mar 14, 2010 09:08 PM
PINKS
May 29, 2006 10:26 PM
DC2*Integra
Sep 20, 2005 12:51 PM
350z-tech
Nov 10, 2001 10:46 PM
