Any of you guys run without ARP headstuds,and have no problems?
A buddy of mine put some on and has had heagasket failure with em,hes tried stock and cometic gaskets,and he is a honda mechanic as well,so thats not the problem,im considering whether to use stock or the ARPs.
every time ive boosted a honda motor with stock headbolts (and stock torque), i lifted the head. however i had a few turbo beaters that i overtorqued about 10lb/ft and had no problems. But I am known for overboosting stock motors... I do it for fun.
now i always run aftermarket head bolts or studs, unless its a beater and dont expect the motor to last. I have the golden eagle studs in my built GSR.
I know that alot of people get away with using the stock bolts, even with a lot of power, but I still recommend getting studs.
Modified by ham at 2:13 PM 3/27/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham »</TD></TR><TR><TD CLASS="quote">every time ive boosted a honda motor with stock headbolts (and stock torque), i lifted the head. however i had a few turbo beaters that i overtorqued the stock head bolts to 65-70lb/ft and had no problems. But I am known for overboosting stock motors... I do it for fun.
I know that alot of people get away with using the stock bolts, even with a lot of power, but I still recommend getting studs.</TD></TR></TABLE>
isnt 65 stock torque spec?
i was talking D series. 63 for the B series. i shouldve said that i overtorqued about 10ft/lb on the budget setups.
run the arp's, we use them in all our builds, and i use off the shelf arp headstuds in my 613whp gsr.
they are cheap enough to get why go stock. especially if its a d series they always have head lift issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not2slo128 »</TD></TR><TR><TD CLASS="quote">stock headbolts are not reusable... arps are.
ARP worked great. TQed mine down to around 80</TD></TR></TABLE>
o i beg to differ
o i beg to differ
I reused my stock headbolts 3 times on my first D motor and twice on my second boosted motor and never had any headlifting problems. If people could tune their cars they wouldnt have these problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbomoe »</TD></TR><TR><TD CLASS="quote">The thing is that im runnin bout 10-12psi on my b-series,not 20-30psi.
I think you have other issues...was the head and block checked for flatness. If one or the other is not flat then you could blow head gaskets. 10-12 psi is nothing...even with stock head bolts.
You should also check your tune....Also your friend being a Honda mechanic means nothing...obviously he doesn't know how to diagnose your problem.
</TD></TR></TABLE>I think you have other issues...was the head and block checked for flatness. If one or the other is not flat then you could blow head gaskets. 10-12 psi is nothing...even with stock head bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE »</TD></TR><TR><TD CLASS="quote">
Also your friend being a Honda mechanic means nothing...obviously he doesn't know how to diagnose your problem.</TD></TR></TABLE>
Most honda "techs" from Honda are parts changers and have no idea what diagnosing is because they arent paid to do so.
Atleast around here. I know of two Honda techs and they are brilliant, the rest have no idea what they are talking about.
WavyIntegra
Jan 25, 2010 02:06 PM
ladysman
Feb 17, 2003 06:26 PM
accordfreak
Dec 16, 2001 07:43 AM
