Annoying Rattle!
Old Mar 26, 2007 | 04:58 AM
kublai's Avatar
Default Annoying Rattle!
Hi GUys...
I'm still trying to fix this annoying rattle of mine thats occuring around the alternator/ps pump area.... From reading the posts... It might be the heatshield so I've removed it and it still happens.. also tapped the heatshield from the cat as well... also not that... SO I got the mechanic stethescope and heard the rattling from the alternator.. so I replaced that..
But the same rattling is still that... thought it was the valve getting out of whack.. but I've adjusted it and its still there! at this point I want to do whatever it takes to get rid of it...
Then I used the stethescope and also heard that similar rattle from the ps pump so I removed the belt and ... as you can guess.. its still there... SO really now at the moment I'm out of ideas and possibilities...
I also just had the timing belt replaced.. and at the same time had the following replaced while the engine was opened..
Cam shaft and crank shaft seals, rocker cover gasket, timing belt tensioner, water pump,pcv, fuel filter, all drive belts, distributor cap and rotor button...
so could it mean whilst they were replacing them they could have stuffed something up?
Sorry for the long post but I need to be detailed so someone can give me some specific advice...
Thanks in advance
Old Mar 26, 2007 | 07:13 AM
teg97's Avatar
Default Re: Annoying Rattle! (kublai)
have you listened to see if it was coming from the a/c compressor if you have one...
Old Mar 26, 2007 | 09:01 AM
itrdave's Avatar
When are you hearing the rattle - certain speed range or throttle opening etc ? And does it sound like exhuast (hollow-ish) ?
Old Mar 26, 2007 | 11:20 AM
SiR99's Avatar
This is probably not the same case as yours, but I had a rattling in my car for long *** time, and it echoed while driving so I could never to put my finger on where it was coming from. I lucky opened one of my turn signals and it was this metal piece that holds the turn signal and it wasnt in place. I had opened the turn signal a while back and didnt put it back right. Try to remember if you have worked on any part of the car since the noise started.
Old Mar 26, 2007 | 03:54 PM
kublai's Avatar
Thanks for the feedback guys... yeah I also thought it was from the a/c compressor... but after i got the stethescope... the noise wasn't really that loud from there....
also it sounds like a tinny rattle... like a tin can type of rattle.. but the rattle isnt in any type of rythem. so are you saying that it could be the exhaust?
I noticed that the rattle is at the most obvious when its in like the 1100 rev range... also when I turn on the air conditioning...
oh sorry.. when I got the timing belts replaced etc... i didnt do it... it was done by Honda... so I trust that they did it correctly.. hopefully
Old Apr 7, 2007 | 11:13 PM
kublai's Avatar
Hey guys... I found the same sound that someone else has...
http://www.youtube.com/watch?v...earch=
its that sound but a more higher tinny sound
Its not the alternator... ps pump... ac compressor as well.. and now it seems like its coming from the flywheel area... any ideas?
Old Apr 8, 2007 | 05:22 AM
vtec.dc2's Avatar
i can't tell anything from that video.. however.. i'll share the most common rattles from hondas
a/c compressor turns on.. you should hear more rattle.. sometimes its less of rattle when you press in the clutch
exhaust rattle is rather obvious and its likely to be heard at certain rpm. if your exhaust is stock, done right, and no defects.. make sure all of connections are tight, all hangers there and you should not have any rattles.
interior rattle is also easy to detect.
injectors will make slight ticking sound and so will valves.
spark plug cover will also add to ratle - remove that and see if thats what you hear
post a better sound clip - hard to tell apart from poor quality of youtube.
Old Apr 8, 2007 | 10:05 AM
MOVE OVER's Avatar
Default Re: Annoying Rattle! (vtec.dc2)
I did not hear much of a rattle on the youtube vid, but I did hear a slight pop in the exhaust. My car has that kind of pop at idle, but I am not sure if that is what you are referring to.
There is another rattle that I have that I am still trying to pinpoint. John informed me that it is most likely a socket that got trapped in a whole under the passenger seat tho I only hear it shift when accelerating or decelerating.
Old Apr 8, 2007 | 04:48 PM
kublai's Avatar
THanks for your feedback guys... Here you go.. I've posted the sound...
its here
http://www.fileden.com/files/2...6.WAV
please let me know what you think... its that noise which makes the car sound like a diesel engine... its a rattling grinding sound...
and also the car is stock... just had the timing belt.. tensioner.. retainer seals all replaced by Honda as well... The noise was captured in the right wheel arch... so near the tranny/clutch area
Modified by kublai at 6:07 PM 4/8/2007
Old Apr 8, 2007 | 06:32 PM
floatfisher's Avatar
it could be maybe ur release bearing
Old Apr 8, 2007 | 07:00 PM
kublai's Avatar
Default Re: (floatfisher)
oic... the car is just parked... does the release bearning still turn even though its stationary?
Old Apr 8, 2007 | 07:15 PM
MOVE OVER's Avatar
Default Re: (kublai)
UPDATE:
My mystery noise turned out to be a tube of chap stick that had miraculously found its way into one of those tiny holes underneath the passenger seat.
Old Apr 9, 2007 | 02:31 PM
kublai's Avatar
Does anyone else have a different suggestion or is it the release bearing?
Old Apr 9, 2007 | 03:05 PM
MOVE OVER's Avatar
Do you hear it while you are inside of the car, or only with the hood up and outside?
Old Apr 9, 2007 | 05:03 PM
kublai's Avatar
Default Re: (ITR 1102)
I can hear it from the inside but its more evident outside.. i wished it was minor like your one!
The-Kid
Feb 8, 2008 03:47 PM
dELfONiK
Feb 21, 2006 06:37 AM
jdadams12
Jan 18, 2006 08:56 AM
NotMYHonda
Nov 27, 2005 06:09 PM
dELfONiK
Nov 15, 2005 05:34 AM
