plastigauge ?'s
Old May 24, 2002 | 04:58 PM
magicwand's Avatar
Default plastigauge ?'s
When plastigauging the rods and mains, what should I tourqe them to? Also , what should the clearance on the mains and rods(Eagle) be for B20B/Vtec turbo? thanks
Old May 24, 2002 | 09:15 PM
cjblmr's Avatar
Default Re: plastigauge ?'s (magicwand)
75% of the torque spec should yield an accurate clearance reading
Old May 25, 2002 | 03:42 AM
magicwand's Avatar
Default Re: plastigauge ?'s (cjblmr)
clearance?
Old May 25, 2002 | 08:46 AM
cjblmr's Avatar
you are using the plastiguage to measure clearance correct?
Old May 25, 2002 | 06:46 PM
jdblack1's Avatar
You should torque them to the torque rating of the bolts you are using. If you don't know you should speak to the manufacturer. It wouldn't guess with rod or main bolts.
Old May 26, 2002 | 08:36 PM
aeolus's Avatar
Default Re: plastigauge ?'s (jdblack1)
If you did torque the rod bolts down to spec,then you would stretch them,Possibly causing you to need new ones if they stretch too much.75% of the normal spec. is good just to check.Usuall clearances are .0011 to .0018 for rod bearings and .0014-.0018 for mains.If you have to mix up some the main bearings to get the right clearances,use the more open tolerances on the middle journals,and use the tighter ones on the outer most.
h1tman
Engine Machining & Assembly
Jul 31, 2016 08:39 AM
b20vtech
Apr 20, 2007 08:51 AM
EG hunter
Apr 8, 2007 09:25 AM
eghonda
Nov 29, 2003 09:22 AM
IH82LOSE
Nov 4, 2003 07:53 PM
